Cree XP-G2 S4 3D emitter
2 Mode driver
Sputnik 10mm TIR
Green GITD bezel
Copper shell & battery sleeve core
Copper & glass reverse clicky switch cover
Rubber switch boot
6mm x 1.5mm green tritium vial
Length – 70mm
Width – 15mm
Weight – 49g (with 10440 cell)
Max – 116lm/ 44lm low
I made this light from some 15mm plumbers tube, copper sheet and other bits & pieces from the parts box.
The reverse clicky switch has a rubber switch boot under the copper & glass cover with a green tritium vial installed.
Two mode, high/ low operated by tightening or loosening the tail after switching on.
Built around a 10440 protected cell.
