Dont know any driver , but what about H150?
really interested in this.
Can you please post the wiring diagram?
Thanks!
Having missed the opportunity a while back to get a Lexel driver, I could be interested in one of these to upgrade my (old) H0something… 3/4?
3 thin wires: black - aux led; white - ground ; red - switch.
You have 3 options for aux led. Connect black wire to aux led on PCB and have 2 aux leds, remove black wire so button aux off or remove led on PCB and connect only black wire for button aux only . Aux resistor is quit low value 180om, so Aux will be bright , if too bright change resistor to something like 470om - 1K
- Updated topic with connection diagram.
I’d be very interested in a 21.9mm one if possible for a d4v2
3A might be on the low side for a d4v2
It is, I was intending to use it with the e21a emitters which suit a lower current
You can probably make it fit with a brass ring
I’d like to thank Quadrupel for both: the driver and help when it turned out the wires in my H03 were arranged differently.
Now I can fully enjoy my Pirate H03. Here comes the gallery.
Arrrr
You did it great!
Got mine as well, still waiting for my H1 tough
just finished modding my H1, its a great driver, i love the version of anduril you flashed on it, got a soft turn on/off
What would be a good emitter to pair with this driver? The stock XM-L2 from an H03? One of the newer well-regarded options like a 519A, or LH351D, etc?
All 3V. emitters will do, but new leds with lower Vf are better.
Finally something interesting. Are there posted any schematics of that driver or not? It is work with DAC MCU or filtered PWM output?
It’s basically thefreemans buck driver schematics, but different components and calculations. He helped me a lot. Yes, Its DAC.
Is there’s posted that schematic here in some BLF topic?
