OP updated:
- added .hex and A2 source code file.
OP updated:
Interested! About time I show some love to the first light I ever got
Too late, all gone… for now.
The suspense!! I’ll pay more attention so I’m not late next time
Thanks!
I’m using this flashing key to flash to flash the driver with: avrdude -p t1616 -c serialupdi -P com3 -U flash:w:ZigZag_V1.1.hex
, but it just fails, with the message: avrdude error: UPDI link initialization failed // avrdude error: initialization failed, rc=-1
This same hardware/command works fine when updating another t1616 driver, such as a Wurkkos TS10.
Any idea what the issue is?
Nevermind — I tried it like 20 times and it eventually worked for some reason.
OK, problem can be pad holes full of paint… so try place pins on pads only
I think you might be right, because it seems to be easier to get it to work now (i.e. maybe I did scratch off some coating).
I was able to compile (with some warnings) the most current version of Anduril 2 by minimally editing/moving around your config files — basically just moving them into the correct folders and editing some paths.
From comparing: your file, similar configs in old versions of Anduril, and those same configs in current Anduril, I think one can see some of the other configuration changes that could be made to more fully comply with the refactoring of Anduril configs.
Edit: Refer to the below post for further updated configuration files.
Edit: some photos
I am interested too for 2 drivers, if you will do a next run ! Thanks
All problem is here V.817 is to complicated to do anything. I’ll stick to V816 forever. And that’s one of reasons why I coded ZigZag, because of ability to control everything In ZigZag code i can add-remove -change modes as i wish. Try to add 4 moonlighs in Anduril
Also interested in this!
O.K. But wait … it fits in to S21E too! Not to small?
Right, some file was applied, but just slight. It almost fits. Just a few minutes with the file and it sits there.
Ah , its to big, so you made 20mm.
Actually 20,5mm, maybe 20,4? fits there. And the pcb is soft so really not much work to be done.
Quick caveat: filing FR4 is not great for your lungs. I’d recommend doing it in a ventilated area (or at least not in the bed/living room) and wearing an FFP2. Thanks to the 'Rona those are plentiful now anyway.
Carla? Is that you?
I’d always just assumed it was “normal” bad for your lungs, like silica or any other fine particulates, is there something I’m not aware of?
As far as I know, unlike carbon fiber, it’s not directly carcinogen, but the fibers appear to still be a severe health risk.
http://www.idph.state.il.us/envhealth/factsheets/fiberglass.htm
I would also be interested in a one of possible 2nd batch.
