Cutting thread (bolt) onto copper for a mod - ?
Hi!
I want to mod one of these fake-XP-L Kings from FastTech.
I have ordered 6 of these: http://intl-outdoor.com/noctigon-3xp-mcpcb-cree-xpg2-s2-1d-leds-p-839.html, 4 for this light.
And I will order the FET King driver from RMM.
Now I am curious about the minimal resistance.
If I copper braid the phosphor-bronze-springs and lower the resistance - what about the 4 screws that hold the board in place?
I would love to use self-made M3 copper Screws for that, to make the resistance even lower. I Also think about soldering them to the board and apply solder on the traces.
But now the question: Is there a silver bullet in cutting threads on copper?
Like isoprop for aluminum or so?
Searching the web just got me answers like “It’s hard to cut in copper…:” - yeah, fine, I know that .
Thank you!
I would just buy brass M3 screws. You’ll waste a lot of time and effort trying to make them in copper.
When there is no switch involved what I do is to use some stranded copper wire, braiding works too, form a loop around a screw and solder it, remove the screw, flatten the loop to form a washer type of thing, solder this/these to the board at the hole, give the solder a rub with sandpaper/fine file to expose the wire, cut to length and solder the other end to the top of the spring, again giving the solder a rub.
When the board is screwed into place the power goes from the cell to the body directly through low resistance copper, no traces or screws to increase the resistance :slight_smile:
Cheers David
At 4x the resistance of copper and 4 screws you’d have the equivalent of a 9-10 gauge copper wire with brass screws.
Hi!
Thanks for your answers!
pommie: That sounds like a plan. I have to look, what I can use of your idea :slight_smile:
@Kloepper: I just googled that aluminum has a lot lower electrical resistance than brass.
That is good, because I have enough aluminum here but no brass. I also ordered 6mmx500mm copper for testing.
In the end, I will use a combination of everything. a lot of solder wick with direct contact to the body and aluminum/copper screws.
I will make a photo if I get it done :slight_smile:
