I have never made a flashlight before and I didn’t use any guides for my build. I came up with pretty much everything by myself so the build might seem unorthodox. Also this is my first post here on BLF. Anyways, I started with a Cree CXB 3590
I struggled finding a heatsink in a convenient shape. I ended up buying this heatsink that is meant for a ceiling mounted bulb.
But the core/center is hollow and I wanted a big, flat and solid mounting point for the LED. So I so I machined a wide aluminum puck with a long solid cylindrical center that press fit into the heat sink. Also some polishing for an aesthetic finish. Sorry I didn’t take any pictures of the machining
I ended up using a 4s3p battery pack, with 3D printed parts. It uses common spring contacts and is held together by some M3 threaded rods.
I browsed Amazon for a cheap and large lens. You can find something like this with the search terms: 4” dome magnifier paperweight.
I used an Ultraboost Driver mounted to the bottom of the heat sink to boost from ~15v to 36v.
Here is the LED mounted on the heat sink. The lens is screwed on top of this part. This allows for some focus adjustment.
A fan was mounted underneath the bottom of the heat sink. The air is forced past the fins of the heat sink to provide the best cooling. Simulations in F360 say it can keep a 100W load under like 70C iirc.
Simple toggle switch for power
And here it is all put together
Also wondering how to get a tighter beam/ longer throw?
Update:
Here’s a quick video I took from my apartment rooftop. ~8k lumens in the video. Rated for 16klm though. Was just underpowered for my initial tests.
Standing 7.5ft away, the beam is ~36”, which I calculated to be a 22.5 degree beam.
And here it is against my wall so you can see it a little better
Also lined the inside with aluminum tape for a little extra reflectance
