I got my hands on an unusual hunting flashlight. Though manufacturer is new, but company accepted challenge of creating flashlight with biult-in color filters. Let`s take a look if Cyansky succeeded in this or not…
you can buy it at:
AMAZON
Specifications
Battery:1*21700
LED 12V XHP35 HI
maximum brightness: 1300 lumens
maximum range 400m (40,000 cd)
Colors: white, green and red
size:
length 16.71 cm / 6.57 inches
head diameter: 4.14cm/1.63”
case diameter: 2.39cm/0.9”
Weight:
With Battery: 240g / 8.4oz
Without battery: 166g / 5.9oz
Packaging and appearance
The package is quite good. Not sort of luxury one, but, overall, it is not cheap. You see that it contains some brand flashlight.
I was really pleased to see runtime charts here. That is a feature that i highly evaluate as sign of honesty from manufacturer.
but i must notice that brightness scale here is presented so cunningly that the thermoregulation saw seems insignificant, and the High mode seems to be really close to Turbo, unlike it is in reality.
The kit includes everything u need, and even more - namely a spare tailcap button. By the way, you also can buy a remote button.
Lanyard is reeally good. Exactly the same as top Fenix flashlights have. But the holster is frankly modest one.
Design of the flashlight is modest as well. There is no complicated and attractive knurling. However, Cyansky H3 appearance is unusual enough to stand out from the crowd of other models.
Modesty in design is balanced by indiscretion in size. The flashlight is frankly rather long. 16.4cm body length is qiote a lot.
The tail button is direct click power one, with ease access to it.
Full click makes sharp and loud sound, not a good for hunting.
The spring is good. I note that it is not bypassed in my review example, but new batch of H3 should have bypass.
Promotional picture promises dual spring, which i a must for gun-mounted flashlight to withstand recoil.
In reality, a single coil of spring is simply soldered to the driver. Looks like this was done in order to make H3 store long 21700 battery, the one with biult-in charge module.
Here he is by the way. It charges quite quickly, in just 3 hours. Good, good.
No spring at head is really uncool for gun-mounted flashlight. I`ve hit H3 several time really hard, the contact at head wasn`t broken, light didnt turned off.
But the question is not contact itself, but that battery bay just crack driver as there is no amortisation at head. I dont say it will happen, but it may happen when there is no spring at head.
For some reason, there are no usual knurling: “pineapple”, square or there is a classic small rhombus. Instead, there are just flat cheeks on flashlight body.
Taking into account the fact that the body is smooth here, and there is no clip, i dont feel like the grip is firm. So, using lanyard is a must.
Nevertheless, the grip itself is comfortable, because body is quite long. Believe me, longer flashlight is way more conveniend then shorter one with no place to put fingers on.
The head seems to be quite massive, but that is normal size head. It just seems to be large, becayse body is smooth and long. In reality it is the same as Sofirn C8G has.
The side button here looks pretty simple. Fortunately, it protrudes strongly enough to be easily felt even with winter gloves. Quite peculiar design, but i dont feel any incovenience with side buton.
Here you can clearly see the ring which changes color filters. I dont feel it is mechanic, suppose that is magnetic switch. The ring moves smoothly. RIing move has a gap of a couple of mm, but it does not interfere. There is no visible gap between ring and body.
The teeth of the bezel are wide, but quite high.
And here is the most interesting. So, at the bottom of a sufficiently deeply textured reflector, a dedomed XHP35 LED is installed. And a “kaleidoscope” of color filters is installed above it.
You can see how everything is organized inside. Well, quite unusual.
Two slats on the sides reveal a spring with a ball at the end. When you select the desired color filter, this ball enters the grooves, fixing the selected position of the ring.
It all looks just freakin awesome - like some odd-eyed Michelin man. Pay attention, it’s not just glass of color filter, but a small reflector under it as well. And on top is already the main large reflector. That a damn precise machinery, not a cheap OEM stuff from unknown basement.
UI
Extremely simple and understandable to any user without a manual. This is good.
But such simplicity means that you can forget about instant access to Turbo mode, which is bad. U can instantly reach Turbo only via modes memory, if turned flashlight off in this mode.
In short, the tail button is OFF-ON, the side button changes the brightness of Low-Mid-High-Turbo by pressing
When you press the button, the strobe is turned on, which is undoubtedly very “necessary” for an underbarrel flashlight. I definetely would prefer shortcut to turbo mode by button hold.
In general, if you need to turn it on and shine, then it’s fine.This works really well for thousands of simple users. As well as this is way too primitive for less number of experienced users.
Cyansky H3. Runtime and Light
The flashlight is well stabilized. 450 lumens is frankly a very modest brightness for High. However, this brightness (in white color) is enough to work within a hundred meters.
The flashlight is really big and could easily handle a much brighter High mode.
It could, but it can’t. The same 1300 lumens of Turbo mode is, again, a fairly low brightness for a flashlight with such dimensions. And the LED itself can work with no problems at the level of 2000 lum, there are bunch of XHP35 flashlight with this brightness in Turbo mode.
With such a mode spacing, with 1300 lumens and textured reflector Cyansky H3 will not show any outstanding throw at all. It is more like mid range flashlight with some throw abilities. Light is good for work withing range of 10 to 100meter, and maximum visible light lies within range of couple of hundreds meters. For a white light of course, because it is way less bright with green filter on, and is just 100lumens with red filter on.
So red light is here good only for walking around, dont exprect any real throw from red light. But green light is quite good, it is not far away from primary white light when you see it alive.
Such moderate throw is not a problem if you hunt with smoothbore guns, actually.
Most of hunters i talked with told me that 100m throw is enough for their needs.
I would consider this light to be sort of mid range with throw abilities. Not bad for some close range work as it would be if reflector was smooth.
This smooth reflector and boosting LED to 2000lumens would increase throw. But i would still keep reflector as is, textured to keep closer range work more comfortable. And would increase throw just by making LED brighter. Nevertheless, throw as is (white and green) is OK. Red light looks to be good for walking around.
OVERALL IMPRESSIONS
Cyansky H3 is a rather unusual flashlight, which has a it`s own CONs and PROs. As almost any other flashlights, actually.
It is positioned as a gun-mounted flashlight for hunting. This is an activity I have nothing to do with. So do not expect that I will be able to reasonably evaluate it`s usefulness for exactly what it was made for.
However, review experience still allows me to highlight some objective pros and cons.
PROs
-> Cyansky is a completely new brand, known only in narrow circles of flashlight forums. It was all the more pleasant to see that the main and most complex functional feature of Cyansky H3, namely the “carousel” of color filters, is far from being primitive construction. Let me remind you that there is a small reflector under each filter, there are grooves for a spring-loaded lock of the position of the color filter selection ring. Functionally, it’s really convenient. Everything is nice and neat at the head of the flashlight.
The choice of color here is actually convenient and I strongly welcome the possibility of this choice in general. The other flashlight supplementary light I’ve seen is Brynite Artemis, was is one of worse brand flashlight i`ve ever seen. Worst is Brynite Apollo, btw.
-> The light distribution here is quite pleasant. You have some reasonable throw and suitable sidelight. Not really much, according to modern standarts. But still good as is.
You can count on good light within a radius of about 300m until turbo drops. This is much more than needed for a smoothbore gun as far as i know.
-> The light itself is stabilized, with a long runtime, thanks to the capacious 21700 battery with fast built-in charging.
-> Grip is comfortable. There is no difficulty in finding the side button. The manufacturer optionally sells a remote button.
CONs
-> Clip would add more firmness to grip. But there is no clip here.
-> As well as there is no spring at the side of the head, which is frankly strange for an gun-mount flashlight.
-> Tail button is too loud
-> 1300 lumens of maximum brightness is frankly way less then you can get from XHP35 LED.
As well as 450 lumens is frankly low level to be called High mode.
-> The XHP35 has a neutral white version, I see no reason why this flashlight has a cold LED installed. May be that is XHP35.3, i`ve heard that it is CW only
-> Thermal control is too aggressive. A flashlight of this size should easily sustain 1000 lumens without cooling.
Here, the brightness drops from the turbo drops to 65% (i.e. 850 lumens) and the flashlight cannot keep even this brightness without cooling. However, most hunters said that they needed gun-mounted light for an exceptionally short period of shooting, and here the influence of thermal control should not be taken into account.
As a result, speaking of stabilized light that does not jump up and down, you can count on either 850 with cooling or 450 lumens without cooling.
-> Red color filter seriously cut the brightness. That is , to be honest, NOT a CON of flashlight, any red light filter would do the same. Even a full turbo only delivers 100 lumens for red light (i.e. either 65 or 30 lumens of continuous light depending on cooling). With green light, however, the situation is better, pretty close to white LED. Whether it’s a lot or not - decide for yourself. Actually, if this was NW LED, it has wider red light waveband in spectrum. CW simply has less red light wave, so it is less bright after pass through filter.
The bottom line is next.
There are virtually no models with built-in color filters on the market now. The one I know, Brynite Artemis, is just awful so i don`t count it. I have no complaints about the Cyansky H3 from the standpoint of the versality of light and convenience of use as such, here the main functional feature, these built-in color filters are well implemented.
Although it is strange that the manufacturer did not increase the brightness up to the 2000 lumens that are easily achievable for this LED. I`m not hunter, so i don`t judge whether there will be any use of these color filter for the hunting.
You should not expect significant range here. Here specialized models with green or red Osram LED performs way better. But they don`t have white light. And sidelight at all. They are really specific.
So, if you need a moderately long-range flashlight with instant change of colors filters, I think Cyansky H3 will fit. Just because it is the only such a model on the market, there are nothing similar.
H3 would be a rather “one more flashlight” without these feature of built in color filters. They change everything because there is nothing comparable on the market now, it has good versality comparing to usual external color filter.
Overall, Cyansky H3 is a specific flashlight, for specific purposes. It has PROs and CONs, and I named those that I found here. Hope it`ll help you to decide if you need this one or not.
