Being somewhat of a noob myself, is connecting the bleeder resistor between the spring (battery plus) and the star the same as connecting it to the ground (the flashlight body)? I thought the stars are used to change driver functions and perhaps that’s not connecting it to ground.
Leviatan, have to tried soldering the resistor between the spring and the outer ring (or you could solder it to the middle pin of 1 of those 7135s)?
Star #1 is directly connected to the grounding ring, it actually can’t be used for changing settings (whereas stars 2, 3, & 4 can be in your typical star firmware). That placement is exactly how I do all my 105c drivers.
This is the reason why drivers like Bistro HD OTSM were developed, the bleeder does not mess up the off timing as the MCU is powered on while the switch is half pressed
OTSM driver can be used with MOSFET or without, depending which mode group you use, but strobes use the FET
So if you use it with FET upgrading to a DTP LED board is nessesary if you put high drain cells in the light
I use 560 Ohm or 1K as bleeder and 4,7K to 47K at tailcap depends on what brightness I want. Blue leds are fine with 1K bleeder and 10 to 47K at tailcap.
I just want to say, “Don’t give up!”. I pretty much thought I should have yesterday, but kept tinkering anyways. According to the OP: “I’m sure there are some drivers that simply won’t work correctly at all after it is added.” I thought I found the driver/firmware that wasn’t compatible with a lighted switch.
I spent about 8 hours figuring out how to make this work. Part of my “fun” was when I asked my wife what color she would prefer in a tailcap. I had it working (for the most part) with yellow, but she thought green would look better. I found out that yellow is terribly inefficient - it requires a lot more current than green.
And in hindsight, green actually worked out better since I was not able to get yellow to work fully. I was able to get forward and reverse mode to work, but it never reset to no memory despite my efforts with various bleeder resistors. It always kept the reverse mode after it was turned off.
What was strange with this driver/firmware is that the normal 500-800 ohms for a bleeder resistor was not even close. I ended up with a 6.9K (22K and 10K ohms in parallel) ohm resistor.
Here are my notes testing the green LEDs, which shows my attempts with different resistors (I count 13 total):
Every attempt required me to solder a different resistor to the driver and test like this:
Here’s the resistor (combination) that eventually worked. Please note this is not the final installation:
Here are a lot of the resistors I was working with:
And finally, which makes this worth all the effort, here’s the switch with the green LEDs and a 47K ohm resistor:
I will post later once I get everything all cleaned up and put together. I’m thrilled I was eventually able to get this to work!
TA Bistro OTSM driver I build and sell have no problems with very low tail resistors, you could drive the LEDs with 5mA if desired
I also got a circular board that replaces the washer which makes a lot more light of the LEDs used
with 6 LEDs and has the option of 2 potentiometers as well balance resistors
In this picture external potentiometes as I am waiting for the 3x3mm ones to arrive
Pink and warm white
I just built up about 10 this past week (Christmas orders for friends), but I have a pretty set standard for what I usually do. Typically just 105c drivers, Mtn FET+1, or BLF A6 drivers. I haven’t tried one of the OTSM drivers yet, but I’m sure they’re good stuff. And I always use the ring board that Lexel mentioned - those really do give good results.
Hello friends !
I ask advice how to make friends with six-voltage drivers type FX-6 , CF FX-17A , RNX-28A , FX-30 with illuminated buttons from OSH Park?
Already tried. I assembled the Convoy L2 with XHP 50.2 and the FX-6 driver. Two-channel board with OSH Park, LEDs nervously flicker
It is necessary to try the bypass resistor between the anode and the cathode, but with what resistance?
