Could do a dischargetest with both batteries (charged them and then discharge each battery with one flashlight and the same mode - if the runtime would be similar, the cells are identical). This would be great, because the trustfire of DD are the best price at the moment.
No problem. The price of DD is great and the most DD products are really nice (the grouß buy things - my friends like the Ultarfire H2, I love the UF 2100) - I think I will buy 2-3 more pairs of the flame trustfire.
So far I have received one set. I ordered protected batteries and received unprotected ones. I contacted DD using their live chat feature and after I explained the situation (in simple terms; keep in mind that their CS people don't deal with the specifics of lithium-ion batteries day in and day out and give them a break), they resolved it to my satisfaction within three minutes.
I order 4 pairs (in the last 2 weeks), because the first pairs was ok and protected. I hope to get the real one, which I order. If not, I would contact Otta.
The protected ones are longer because of the circuit board on the negative bottom side. If you look closely at the picture, the protectives on have kind of a notch where the circuit board is
Correct. And if you look close enough you will see the metal strip running form the pcb negative end to the positive terminal inside the wrapping that is about 1/8" wide. I'm going to take a picture so guys can see that the unpotected cells look different like Tim said about the notch and that they are shorter vs the protected ones. Give me a sec.
I ordered C8 and it came today. I know that DD has slightly fishy reputation (summer is really trying to correct that) but despite that I was a little bit surprised that flashlight came without stainless steel bezel. If you carefully read item description they don't mention SS bezel but pictures suggest otherwise (http://www.dinodirect.com/flashlight-900lumens-5mode.html) And this is really to cheesy even for DD.
Otherwise flashlight is quite good. There are few cosmetic glitches and as usual lens rattles when pill is tightened all the way, reflector and led were clean and without significant imperfections. Current at tail cap is 2.5A/1.15A/0.11A.
Overall not a bad deal due to the lower price but it still leaves bad aftertaste ...
got my Trustfire protected today from DD. Shipped at 4.09V Mine are protected thankfully. Protection circuit is at the top, I have heard most are at the bottom? Unfortunately the batteries from DD arrived before my C8 from KD. Guess I'll just roll them around...
this is my 1st purchase of an 18650 battery. I was under the impression that the little ribbed area on top of the battery was the protection circuit? Is that not true? Does it need one of these ribbed areas on the bottom also? Mine do not have it on the bottom. Any other way to tell? I have some pictures, they are JPEGS. I will gladly post them if someone can tell me how. Thanks again.
can someone see this and tell me if it's protected? What sort of a link do you need to post a picture here? I do it in a photography forum often. Thanks.
