Sofirn SP70 is a powerful outdoor flashlight designed for outdoor activities like camping, hiking, fishing or hunting. It can be operated with two 26650 or 18650 (with sleeves) Lithium-ion rechargeable batteries. Tail switch powers on / off, side switch controls two mode groups: Group 1 with 6 brightness levels and Group 2 with ramping capability.
- Order Subtotal: US$61.59
- Coupon Code: BGSP70 (expires 2019/4/26)
- Coupon Discount: US$11.59
- Grand Total:US$50.00
https://www.banggood.com/Sofirn-SP70-XHP70_2-With-ATR-2-Groups-7Modes-5500LM-Ultra-bright-Tactical-18650-26650-LED-Flashlight-p-1446325.html?p=R4240016492493201711&custlinkid=219321
Specification:
XHP70.2 LED with a lifespan of 50,000 hours
Working Voltage: 5.6 V - 8.4 V
Battery Options: Two 26650 or 18650 Li-ion batteries
Dimension: 250mm (length)× 90mm (head diameter)
Weight: 625 grams (without batteries)
Flashlight body: 6061 aluminum alloy, CNC manufactured to Military Grade Specification type III hard-anodized anti-abrasive finish to get solid built body, anti-crash geometry.
Toughened mineral glass lens
The waterproof level: in accordance with IP68
Reverse polarity protection from improper battery installation
Mode Memory:Last mode remembered - it memorizes the last brightness level used in the general modes (except Beacon)
Advanced Temperature Regulation (ATR) technology: ATR will adjust the brightness level automatically when the driver temperature reaches 60°C (140 °F) to prevent overheating
Automatic Stepdown: Turbo mode steps down to High mode after 3 minutes of operation to prevent overheating. High mode steps down after 30 minutes of illuminating.
Power Indicator: Turn on the light, the side indicator shows the battery power for 5 seconds. Green is good enough power, orange is half power, red is short of power, flashing red is power running out, please replace or recharge batteries ASAP. In Standby Status, the indicator is Green as locator in the dark.
Operation Instruction:
Half press the tail switch for momentary-on. Fully press tail switch to power on or cut off. When the light is on, the side switch controls all flashlight functions as follows:
Group 1: 6 modes (default group)
Click and hold the side switch to cycle through brightness levels: Eco-Low-Mid-High, release when you find the level you need.
Double-click to activate Turbo mode, one click to return last brightness.
Click to Standby, the main LED turns off but side indicator is green as locator in the dark. Click to turn on the main LED again
In Standby Status
Click and hold to Moon, click goes back to Standby
Four fast clicks to active the lock-out, the main LED blinks twice, the indicator LED turns off. When in lock-out status, only four fast clicks will reactive the light, all other operations only get two blinks
Six fast clicks change from Group 1 to Group 2 or the other way around
Eight fast clicks to active Beacon which light up 0.1s in every 2 seconds
Group 2: Ramping
Click and hold side switch to ramp up or down. Ramping changes direction when the button is being clicked and held again within 1.5 seconds; same direction when ramping again after 1.5 seconds.
The light blinks once time when it reaches Moon or Turbo mode.
Click to go to Standby, another click turns on the light.
Package included:
1 x flashlight
1 x strap
1 x replace rubber cap for side switch
2 x replace Orings
2 x key rings
2 xbattery adapter
