- Order Subtotal: US$79.95
- Coupon Discount: US$34.96
- Grand Total:US$44.99
- Code: BGQ8
Expired On: 2019/05/31
BLF Q8 4x XP-L 5000LM Professional Multiple Operation Procedure Super Bright LED Flashlight
4.99 out of 5
407 Reviews
Specification:
| Product name: | BLF Q8 4X XP-L 5000LM Professional Super Bright LED Flashlight |
| Brand: | BLF |
| Model: | Q8 |
| Emitter Type: | XP-L HD V6 3D |
| Light temperature: | 4750K-5000K |
| Light color: | Neutral White |
| Mode: | Smooth ramping or mode set operation |
| Material: | Aerospace grade aluminum alloy construction |
| Total Emitters: | 4x |
| Battery Configurations: | 4 x 18650 or unprotected button top (not included) |
| Working Voltage: | 3-4.2v |
| Switch Type: | Electronic switch |
| Switch Location: | Body side of the flashlight |
| Peak Beam Intensity: | 50,000+ cd |
| Impact Resistant | 1.2meters |
| Max Output: | 5000+ lumens |
| Range: | 450+ meters (max) |
| Lens: | High transmittance glass |
| Reflector: | Aluminum alloy mirror reflective cup |
| Waterproof: | IPX-8 waterproof |
| Color: | Black |
| Weight: | 400g without battery |
| Size: | 132mm x 59mm x 50mm(length x head x body diameter) |
Features:
• Compact and lightweight 5000 Lumens flashlight
• Utilizes four XP-L LEDs
• Uses four 18650 batteries for maximum runtime up to 1500hours
• Features advanced temperature regulation (ATR) technology
• Integrated power indicator in side switch indicates remaining battery power
• Flashlight can blink out voltage with 0.1V accuracy
• Intelligent memory function for brightness levels
• Direct access to ultralow and turbo outputs
• High transmittance glass
• Stainless steel bezel ring protects core components from damage
• Constructed from aerospace grade aluminum alloy
• HAIII military grade hard-anodized
• Waterproof in accordance with IPX-8
• Tail stand capability
Mode,Lumens and runtime:
| Mode Groups: | Runtime and Lumens (manufacturer tested,it will be a little bit different from the real data ) | |||||||
| Group1: | Moon 2LM/1500h | Turbo 5000LM/40min |
| Group2: | Moon 2LM/1500h | Low 160LM/33h | Turbo 5000LM/40min |
| Group3: | Moon 2LM/1500h | Low 70LM/66h | Mid 1250LM/8h | Turbo 5000LM/40min |
| Group4: | Moon 2LM/1500h | Ultralow 10LM/150h | Low 160LM/33h | Mid 1500LM/6h | Turbo 5000LM40min |
| Group5: | Moon 2LM/1500h | Ultralow 10LM/150h | Low1 70LM/66h | Low2 160LM/33h | Mid 1500LM/6h | Turbo 5000LM/40min |
| Group6: | Moon 2LM/1500h | Ultralow 5LM/150h | Low 70LM/33h | Mid1 240LM/17h | Mid2 1100LM/10h | High 2500LM/3h | Turbo 5000LM/40min |
| Group7: | Moon 2LM/1500h | Ultralow1 10LM/400h | Ultralow2 35LM/140h | Ultralow3 95LM/54h | Low1 160LM/33h | Mid 1350LM/8h | High 2500LM/3h | Turbo 5000LM40min |
| Group8: | Moon 2LM/1500h | Low 160LM/33h | Mid 750LM/17h | High 2100LM/5h |
| Group9: | Moon 2LM/1500h | Ultralow 10LM/150h | Mid 520LM/20h | Turbo 5000LM/40min |
| Group10: | Moon 2LM/1500h | Ultralow 10LM/150h | Mid 1500LM/6h | Turbo 5000LM/40min |
| Group11: | Moon 2LM/1500h | Low 160LM/33h | Mid 1350LM/8h | Turbo 5000LM/40min |
| Group12: | Moon 2LM/1500h | Ultralow 5LM/600h | Low 150LM/33h | Mid 1700LM/5.5h | Turbo 5000LM/40min |
Package included:
1 x BLF Q8 4X XP-L 5000LM Professional Super Bright LED Flashlight
2 x Flashlight Body Tube O-ring
1 x Flashlight Head Lens O-ring
1 x Switch cover
1 x English Manual
Note:
Before ordering please make sure that you know how to operate the flashlight.
How to use the UI: bit.ly/narsilinfo
For the safety to the battery: bit.ly/lionsafety
For more information to see: bit.ly/blfq8
Product review from BLF Forum:https://budgetlightforum.com/t/-/39069
