Oh I know they can all handle the output well enough, but I’m talking about run time.
When you take it out you want to minimise battery changes and maximise run time. The Sanyo 2600mAh will get you maximal run time if run on high mode. And the fact that they are like $10-11 a pair makes it even sweeter.
My back is still not the best. But I’m trying to live with it.
I figured I better go fishing with him before he leaves for college. He went again to day. He ask me to go, but I told him I had to get things done today.
The 3400mAh Panasonics do have a higher capacity, but only at low current draws. In a light like the TN31 nodded which needs significantly higher current the Sanyo 18650 2600mAh has less voltage sag which translates to longer run time.
To put it simply, the Sanyo just handles high currents better which is why it lasts longer.
It seems like he’s saying the Pana capacity is less than the Sanyos at 3+ amp draw rate; it’s not but I don’t think that is what he is telling us.
Looking at the Battery Comparator (awesome tool) it looks to me like the Panas’ lower and faster voltage drop (or sag, as described above) will have us wanting to pop in fresh batteries before you use all of their capacity. And the light won’t be as bright from the start.
For a situation where you want all the juice available at the lower and dimmer voltage (especially when you don’t have spares and need light), then the Panas will run longer in that dimmer state.
The Sanyos let the light stay in the high mode for longer. If you ran a light at 3A with both cells, you’d find the Panasonic would indeed last longer, but it would also be the first to dim. That’s basically what I’m trying to say.
That’s only true for linear driving.In case of switching driver better is battery with higher energy content (Wh) at required current.And current remains constant until batteries are empty(if it is a good driver).
Not sure about that . . first, the curves appear to be based on constant current with voltage dropping. But even if the juice is sucked out faster with an increasing current to maintain near constant output, then the curve will drop faster (or the driver may simply shut down early when voltage isn’t high enough to maintain current).
The Panas show more capacity left but when you look at the curve and note it’s only available @ <3v running 5A . . then it’s pretty much shut down time for a lot of lights (and the way many of us use our Lion cells). Personally, I try not to run mine below about 3.1-3.2v and frequently change them out before then, even if the spec is 2.75 on some cells.
ok after reading slewflash and gottazooms explanations, i think the sanyos will suit me better, as i know already know that i will be using these for mainly on turbo mode for the tom e super shocker and vinhs k40 thrower.
Not sure about the K40, but it’ll fit the Shocker well.
If the K40 battery carrier is the same as the TN31 then it would fit in the K40 battery carrier. Also something to note, The Sanyos will have a much harder time fitting in the TN30. It fits, but it’s pretty tight. It’s not hard to get out because of the way the carrier is designed, but it requires a little effort trying to get them in.
EDIT: And yes, the ones you linked are the protected Sanyo 2600mAh cells (UR18650FM).
