I have four Energizer AA NiMH cells rated at 2300 mAh. Not entirely sure how old these cells are; maybe around 5 years??
I am wanting to maximize the capacity of these cells by running "cycle" mode on the charger. The charger should charge first, followed by discharge, and then repeat until the number of cycles has been completed.
Charge current set at 200 mA. Discharge current not adjustable when running in cycle mode, and discharge current defaults to 1000 mA.
I tested (cycled) just one of these Energizer cells first to see what the results would be before cycling the remaining three cells.
On first cycle, the discharge capacity for the single test cell was around 2163 mAh. Not bad!! But after the second cycle the discharge capacity had dropped dramatically to only 917 mAh!!?? And after the third cycle, the cell capacity dropped a bit again to 912 mAh!!??
There appears to be something wrong here as there should not be a dramatic drop in measured cell capacity so soon after each cycle!?
Note that all of the Energizer cells had some existing charge on them, and I didn't (manually) discharge the test cell first before starting the cycling process. Maybe because I didn't do a discharge first could have caused some issues with the charger cycling process?
I didn't monitor the charger cycling process continuously, I just checked progress every couple of hours or so.
I did note that the charging phase of cycling seemed to be relatively quick despite a low charge current of 200 mA. Certainly for the first cycle, the charge just topped up the existing cell charge, so a quick charge was to be expected. But for the subsequent second and third cycles, the cell should have been (near) fully discharged and I would have expected a longer charge time for these last cycles, but it didn't happen!
I'm wondering whether the test cell could be suffering from "capacity memory"? Although for NiMH cells, this "memory" issue is, according to various online sources, should be minimal to near non-existent.
Or is there an issue with the charger?
Or maybe issues with both the cell and the charger!?
Ideas?
