I was in a HomeDepot near my work place today, and noticed 2 skids full of these Defiant 200 Lumen 3-Pack lights for an in-store sale of only 12 bucks. i grabbed a pack of them since i seen others going off with arm-fulls of these lights, ( maybe for xmas gifts
They are all aluminum, uses 3 AAA cells, (which came with the batteries included with the lights) i noticed the emitters and they looked like they were XP-G2s, but was not sure until i got them home to inspect them closer with a magnifier.
As suspected, thay are XP-G2 emitters, well centered, and with a very nice almost Neutral-White tint, smooth beam, and 3 modes. ( Hi, low, and strobe)
I did a quick tail-cap amp check on the stock batteries included, and got exactly 1 amp on high, and 0.15 amps on Low. ( should have a good run time on low.)
On the package they say 200 Lumenrs, 4 hours run time, ( i dont know if that on high or low or strobe) throw distance of 170 meters.
I just went outside, its a clear night, and the throw distance seems to be atleast 170 meters or more on high so it sounds accurate.
Probably the three pack is CA only, but we have them in two packs in the US. At least Home Depot and/or Brinkman are smart enough to keep putting out these lights. They sell like crazy every year and they are a great light for non-flashaholics. I hope they continue to sell like crazy, so maybe they will be in the HD stores for years to come.
I can't make out the SKU on the package. Is it 1000 765 505?
EDIT: They look different then the 2 packs in the US. The tail cap is flat in the US models and I don't think they have xpg2's. They are also rated at 120 lumens on the package in the US.
SKU is 1000 785 505. Here is the wierd thing though⦠i search for that number on HDsā site, and it came up with Arrow T50 staples for that number.
I found antother number on the back near the UPC code, and a search of that got a ā No results Foundā. Maybe these lights are discontinued.
Did the price end in a ā0ā⦠if so they are discontinued. I checked that SKU online at a dozen stores around here and came up blank. Den been hallucinating flashlights again?
SKU is 1000 785 505. Here is the wierd thing though.. i search for that number on HDsā site, and it came up with Arrow T50 staples for that number.
Thank you. It pulls up as a 60watt bulb when I try the inventory tracker for my store. Searched a little. Doesn't seem available in the US. Nice find.
I bought 2 pack of these lights, my Home Depot only got the ones 2/$10. itās Cree XB-D LED but i like the reflector , itās DD and look like 17mm driver could fit in there and some extra room for more 7135 chips
cut the spring at the tail, and loosen the head a little ,add adapter for 18650⦠voilaā¦it became 18650 light
it is now slightly brighter than the original, too bad i canāt figure out how to take the lens off( maybe itās glued?), 28mm fresnel lens fit in there.
