Dephosphoring for Science! 🔵 NV1010,LHP73B,F45R
I had some time today to “experiment” with a couple of emitters. So I lightly documented it, for future reference…
  • Convoy NV1010 6500K :white_check_mark: :blue_square:
  • Lumen Pioneer LHP73B 6500K :white_check_mark: :blue_square:
  • Convoy F45R 5000K :white_check_mark: :blue_circle:
All were successfully dephosphored with a utility blade, isopropylalcohol as lubricant and some patience. Some kind of magnification is easier for the eyes too.
I started with this NV1010, which arrived with a small defect - one edge/side was broken. This did not affect the performance of the emitter though.
With a razor blade, you can carefully scrape off the phosphor. I use some IPA to lubricate the surface. Start with the outer 4 sides turning 90° every couple of passes.
After a while, you will feel the seperation between every individual die, and a “nails on chalkboard” screeching sound will arise. This means you are on the hard surface of the die and all phosphor has been removed.
Now you can work in circular motions per individual die.
After 10-15 mins of scraping and wiping, the emitter is almost completely phosphor free.
Awkward “phone and two prongs of the multimeter in hands” diode check (sorry for the bad quality!:
I repeated the same process for the LHP73B.
The LHP73B has smaller individual dies, and this makes it a bit more tedious.
Feeling lucky (and destructive) , I wanted to try an emitter with visible bond wires. I had two candidates:
The F45R, and a Luminus SFT-42R.
In the picture you can clearly see that the F45R has a shiny, (what I think to be an) epoxy layer over the white silicone.
I know for a fact that Luminus’s white layer is very brittle and easily ruined, that’s why I opted for the F45R.
With a bit of luck, the bondwires had an extra layer of protection.
I used the same method as before.
In between:
Finished:
I had no hopes for it to work out for an “SFT” style emitter with bare bond wires!
I must note that the circular “glass-like” surface is different than the previous emitters. Less abrasion-resistant is my best guess.
My multimeter+emitter does not light up testing this one, not strong enough (small hikoki pen tester) or a dead emitter?
So, I mount it in my test rig (Convoy Z1):
LET THERE BE BLUE, ROUND LIGHT!
The blue NV1010 will be mounted solo in a 3X21C, for another 230mm fresnel FET build (see:loudener).
The blue LHP73B will be mounted in an M21A host with OP reflector, with the correct 20A driver.
And for now, the F45R will remain in the Z1,until another emitter needs my test bench :grin:.
I like blue.
15 Thanks
Cool, you did disassembling so I don’t have to :sweat_smile:
I think most of these square san’an type chips are similar in production process, no?
I’m more interested in the more niche round ones, or I might try my luck with some Luminus emitters.
I’ll try to use a sharp, plastic spudger in the future though.
