can someone explain what are the main characteristics of this four types of drivers:
linear, boost, buck, regulated drivers (I kinda know why first 2 are called that way)!
Thanks for a "Understanding the drivers 101 lesson" :P
Linear: current out equals current in(except for small current use of driver). Most efficient when Vbattery is just above Vf led.
Boost: voltage out is greater than voltage in and current out is less than current in. Hard to make in a small package with decent drive currents. Most efficient when Vbattery is just below Vf led.
Buck: voltage out is less than voltage in and current out is more than current in. Supposedly easier to build with decent output but still most efficient when Vbattery is just above Vf of led.
Regulated is supposed to mean the current is controlled but it seems that often the specs on a driver just note the output with fully charged cells. Fully regulated to me means that driver output us constant over most of the charge cycle of a cell.
Hope this helps and isn’t too far from accurate.
of course it helps, thanks.
Idea is to understand them better so I could modify them easier ![]()
Fully regulated is often used for buck/boost drivers than can do both. But there are only few good ones..
And the boost part isn't needed if the input voltage even with totally flat cells will still be above the Vf.
some nice info here, thanks. Now I can proceed and investigate what component is doing what exactly ![]()
Some great info. ![]()
My only contribution would be how the term ‘regulation’ is defined.
To me this means “controlled” rather than 100% constant output.
For example companies such as Maglite use regulation in a different way as do Led Lenser.
e.g.
An XL200 Maglite is regulated to offer high output when you first turn it on. However it’ll step down after ‘x’ minutes. This is usually not easy to perceive with the eye, but gives the user extended runtimes. Once stepped down it will maintain this lower brightness level until the batteries are pretty much depleted.
Turning it off and on again will reset the regulation to offer maximum output again. This means if you use the torch for short periods you can always get max output, but if you use it for extended periods the light is clever enough to try an maximise the runtime for you. As the user you can easily over ride this.
The Mini Maglite Pro’s use a different kind of regulation again. They still offer max output, but instead of stepping down it gradually dims to a lower output. Again this is designed to be difficult to notice by eye, but the aim is to maximise the performance, output and runtime on alkaline cells. It also means a Mini Mag Pro will offer very similar ability on alkaline, lithium or NiMh. Something most other AA torches can’t do.
Many other “premium” brands also use clever regulation. EagleTac with the D25 series also use a step down, but this is for heat management rather than anything else. When you first select high it automatically gives you Turbo for a couple of mins, it then auto steps down to high to prevent overheating.
Most budget lights don’t offer the ‘clever’ regulation and are more aimed at either preventing you frying the light (multicell or poorer thermally managed lights) or extended the output above and beyond a more normal output.
End of last year there was a special on a “BLF Mini” based on the Trusfire mini. It’s a nice compact keychain 1xRCR123 light.
It has regulation so that in high it puts out a massive amount of light for it’s size. This is very cool but as the voltage drops it quickly falls out of regulation and is a lot less bright.
For instance, @ 4.11 volts (resting) it outputs a tonne of light. At 3.90 volts (resting) it seems to have fallen out of regulation and is a lot dimmer.
My premium lights seem don’t seem to dim (visually) even when the battery is down to 3.6 volts (resting).
Not all forms of regulation are equal.
This is written by Le Quack at LPF. Here’s the link: How laser diode drivers work; An Explanatory Thread | Laser Pointer Forums - Discuss Laser Pointers | High Power Lasers
There are roughly 4 types of drivers out there:
Buck
Boost
Buck-Boost
Linear
Each of these designs have their own pros and cons. They are cost, reliability, and efficiency. (the rating system is by ’s, there are a max of 4. a - is half a)
All regulators can be made to be constant current; it’s just how feedback is changed.
But, before we go over the types of regulators, we must go over the feedback method used!
CURRENT SENSE RESISTOR
Current sense resistors are typically low valued resistors put in series with the load (usually a laser diode). For any given current, there is a voltage drop across the resistor. For most regulators, the feedback voltage reference is around 1.25 volts.
This is rather inefficient, as the resistor must have 1.25 volts across it to maintain regulation. For example, lets say, you want 250 mA. The resistance can be found with R = E/I. So, we would need a 5 ohm resistor!
However, when we calculate the power lost, (with P = I * E) it’s approximately 310 mW of power is lost in the resistor. 310 mW is a lot of power lost in something that’s just supposed to be sensing correct? How can we fix this?
Well, some regulators do you a favor and instead have a much lower internal voltage reference, somewhere in the 200 mV range. Using the same values above, we can find that the resistor would need be around 0.8 ohms. With 250 mA of current flowing through it, it would lose only 50 mW of power! That’s a pretty decent increase in efficiency over a 1.25 volt reference!
For regulators that DON’T do you this favor, you can correct it very easily yourself. If you take an op amp, and use a ….0.1 ohm resistor, say. The voltage across the resistor is around 25 mV.
You take the op amp, and use it to amplify the voltage to 1.25, so the regulator thinks that it’s 1.25 volts, and will regulate the current as necessary. It would keep it at 250 mA, but there’s a LOT less power dropped (only 6 mW!) across the resistor as a result. It makes it MUCH more efficient.
This method can be applied to any regulator, switching, or linear. You can make the famous LM317 work a lot better using this… instead of dropping 3 volts by default, it’ll only drop around 1.5-2 volts instead! (basically, you won’t need as much “default” voltage to get it regulating right)
LINEAR REGULATORS
Linear regulators are usually the most simple. The LM317 driver is the most common you’ll ever hear about. They work with two internal parts; an op amp, and a transistor.
The op amp inside has a 1.25 volt reference on it’s + input, and the output is tied to the transistor’s base. The - input of the op amp is tied to the “ADJUST” pin, where you usually have it measure voltage across the current sense resistor. The op amp will turn the transistor into its linear region; (hence the name linear regulator) where the transistor basically acts like a resistor. It will turn it on more or off more to maintain 1.25 volts at the - input of the op amp, and will regulate current as necessary this way.
They are only good if your laser diode’s forward voltage is LOWER than your supply voltage. However, the more your supply voltage is over your laser diode’s forward voltage, the more inefficient it becomes.
Cost wise, they are very very cheap. At max, they require maybe 3 external components.
Cost:
Reliability is basically 100%; these almost never fail.
Reliability:
Efficiency is where these really lose it. A linear regulator will drop the excess voltage as HEAT, which becomes wasted. However, if the input voltage is close to the output voltage, then efficiency is improved.
Efficiency:
Buck Regulator
A buck regulator is a switching step DOWN regulator. Most of these for our purposes are monolithic; they contain all needed parts inside of the IC package.
They step down voltage by using a switch, typically a MOSFET, a type of transistor. By rapidly turning the switch off and on, (as fast as 2 mhz!) they chop the DC supply up into something called a square wave.
The square wave is then fed into an inductor, which smooths it out into an average voltage of the square wave. It is then fed through a smoothing capacitor, which then smooths out the voltage even further, to essentially pure DC. Once it is fed through the capacitor, it goes through the current sense resistor, to the feedback op amp.
Feedback in a buck regulator works by modifying the duty cycle of the MOSFET. This means, that when the voltage across the current sense resistor is too high, (AKA too much current) the regulator will turn off for a little while to drop the output voltage a bit. If the voltage then becomes too low, the regulator will turn back on again, causing the voltage to then rise. This repeats again and again thousands of times a second to maintain regulation.
Buck regulators are only good if your laser diodes forward voltage is LOWER than your supply voltage. They can supply additional current with more supply voltage though!
Cost is generally higher than linear regulators, though some can be relatively cheap.
Cost: +
Reliability is pretty good in buck regulators. However, they can be somewhat harder to troubleshoot due to their increased complexity in respect to linear regulators.
Reliability: +
Efficiency is very good with buck regulators. The higher your supply voltage is the more output current your regulator can supply. There is usually very little heat lost in these types of regulators.
Efficiency:
Boost Regulators
Boost regulators are rather common in single cell (one lithium ion battery)builds. They step UP voltage at the expense of increased current draw from the supply. Again, they are usually monolithic, with almost all of the parts needed included within the IC’s package.
Boost regulators work again using a MOSFET typically. There is an inductor in series with a mosfet, and a diode that feeds away from the MOSFET’s drain. An inductor is a coil of wire. When an electric current flows through it, it creates a magnetic field. When current stops flowing through it, the magnetic field dumps back into the wire preventing the current from stopping instantly. A boost converter takes advantage of this property; As the MOSFET is in its on stage current flows through the inductor. All is happy in the world, but then the mosfet turns off! Oh noes, where’s all that magnetic field current going to go?
Well, the current is dumped into voltage. The more current, the higher the voltage is boosted (up to a point, anyway, there’s something called saturation that makes really high voltages impossible). So, the voltage is looking for a way out, and see’s the diode right next to the mosfet’s drain. It goes through that, and is fed into a smoothing capacitor, so that the output is DC. Then through a current sense resistor, and then to your laser diode.
Feedback is essentially the same as a buck regulator. It will alter the duty cycle as necessary to keep a certain voltage across the current sense resistor, and thus keep a certain current flowing through your laser diode.
Boost regulators are great if your laser diode’s forward voltage is ABOVE your supply voltage. They increase voltage at the expense of more current drawn from your battery.
Boost regulators are getting very cost friendly. They can be had for very cheap nowadays; (as shown here FREE DIY open source BOOST driver!!! Tested & working!!)
Cost: ±
Reliability CAN be lacking in some cheaper drivers. They can be somewhat difficult to troubleshoot, as well. Because they boost voltage, they can kill your laser diode if it is connected up backwards. (the regulator will try to boost the voltage more and more until your laser diode dies from reverse overvoltage!) Some drivers have protection against this though.
Reliability: -
Efficiency is very good with any switching regulator; however, boost regulators typically have a slightly lower efficiency than most bucking regulators that I’ve personally seen.
Efficiency: +
Buck Boost Regulator
Buck boost regulators are a combination of the above two switching regulators (there’s also SEPIC, but that is effectively the same thing as buck/boost, just the component layout is a bit different). This topology maintains regulation by boosting or bucking the voltage output as necessary. Basically, it can step down, or step up the voltage as it sees fit, to run your laser diode at a specific current. You can use this in a single cell, or multi-cell build for your laser.
Operation is a combination of boost and buck regulation. Feedback is achieved the same exact way with all switching regulators, by modifying the switch’s duty cycle.
They are great for ALL builds. Single or multiple cell, this driver type really just doesn’t care!
Be prepared to pay more money (typically) for buck boost drivers, as they have much more utility than basic linear, bucks, or boost drivers alone.
Cost:
Reliability is decent with most.
Reliability: -
Efficiency depends on what mode it’s in; typically more efficient in bucking mode.
Efficiency: +
With any laser diode driver, you must find one that fits what your looking for. Linear drivers are the most cost effective. Bucking regulators are great if you want more run time than linear drivers, but typically cost more. Boost regulators are perfect if you want to use just one lithium cell for your build, while Buck/boost drivers are perfect for just about anything; the only compromise is expense.
I hope you enjoyed my explanation of laser diode drivers!
Sorry, but that explanation is not for dummy's.
Too many non-understandable words and abbreviations. It could be made much easier to understand !
So if someone can, please let us know, so everybody can understand it somehow.
You left out a whole other class of drivers: bad drivers, drunk drivers, women drivers, texting drivers, teen drivers… and various combinations thereof… |(
My bad, it is indeed difficult to understand.
In a nutshell:
Buck: Step down transformer, such as 220V to 110V
Boost: Step up transformer, such as 110V to 220V
(The transformer analogy represents the function of the drivers. It doesn’t show how it actually works; that’s a whole new story.)
Linear: If we have a 2.8A linear driver, it sucks 2.8A from the cells, and that’s what you’re going to measure with your current meter. It burns away excess voltage as heat, ie) if the cell voltage is 4.0V and the required voltage of the LED at 2.8A is 3.5V, it burns away 0.5V as heat. 0.5V x 2.8A = 1.4 Watts.
The part missing is then clearly ‘electronics 101’, not ‘led drivers 101’.
Nothing wrong with that, of course, but I wonder if it’s still the intended focus of the thread?
(I remember some very nice US military training videos from the 50s/60s, covering most of the needed knowledge with really nice hand made animations.
I post them here when I find them online)
wow, I must print this out, for reference later on ![]()
