So I’ve searched Parametrec’s database without luck. Is anybody familiar with a 18650 light which also supports 2xCR123, has a tail clicky and integrated charging (USB-C preferred)? High CRI and/or a good tint is VERY important but depending on price/warranty I am certainly willing to swap emitters to my taste. There are a number of very nice side-switch lights which come close but I strongly prefer a tail clicky. the 18650/CR123 is important but I don’t mind a 21700 battery tube as long as it supports the 1s/2s battery voltage.
That’s asking for alot.
Separate mode switch on the side, or single button operation only?
Definitely single button only
Is there any light that supports 2 x CR123A and has integrated charging? The safety implications are alarming.
Nitecore has several…here’s an 18650 but they have 21700 as well. I don’t know if outfits like Klarus might, or $$ ones like Elzetta, but check the “tactical” oriented brands. Most of those folks can’t give up the 123s and “dual fuel” is right up their alley.
Do you 100% need CR123A compatibility? Because if not, there’s a JKK26 light you might like.
Otherwise, just go with the Nitecore MH11.
Skilhunt M200 and M300.
Oh yeah, I completely forgot about Skillhunt as well ![]()
@brewster, integrated charging and 2x CR123As is fine. Lights with integrated charging with that compatibility check if the voltage exceeds a safe value(>4.5-5V probably) and then prevents charging.
Yes. Eagtac, probably others too.
To have integrated charging, the tail switch kinda has to be an e-switch, like the FW3A family, KR4, Acebeam L17, etc., right? Do those even count as “clicky” switches?
A mechanical tail-clicky with onboard charging can be tricky, because either:
— you need to physically turn the light on to charge it, or
— it needs to be a dual-tube design, or
— it needs to have diodes in the tailcap to allow charging.
Convoy BD3 has tailswitch and integrated charging. I don’t know if it works with 2 CR123’s.
