Digital camera battery problem
For some reason the low voltage warning on my older canon A540 has gotten higher and higher, for about 3 years it would shut down the camera when they were down to 90% charge, but recently fully charged batteries fresh off the charger read as dead and the camera shuts itself off immediately before i can take any pictures.
The camera uses 2 AA batteries, and since i can’t afford a new camera i was thinking of buying a 14500 cell and a dummy cell, but at 4.2V it may fry the electronics.
Is there a way i can regulate the max output to say 3.2V, maybe a dummy cell with a circuit that eats up some of the voltage or some kind of circuitry?
Is there a setting for different batteries for example rechargeable or Alkaline? If so it may be on the wrong setting.
Sounds like a good time to install http://chdk.wikia.com/wiki/CHDK
it has no battery settings, but my gps does
@leaftye i have been using it for years, but no effect on this issue, i assume its a hardware problem not a software one
Not all nimhs are created equal, there’s Eneloops and pretty much everything else, so unless you’re already using Eneloops, I would question the batteries.
My camera is sensitive to rechargeables when I use older batteries; they have to be close to being fresh off the charger or I get a dead battery shutdown.
Does your camera work with alkalines? They run 1.60v when fresh. Mine works readily with alkalines but drains them fast.
Try eneloops, or consider trying a LifePo cell and monitor the charging cycle so it doesn’t charge past 3.3 volts…that’s likely a 95% or higher charge.
Bort, are you using eneloops?
If you’re going li-ion, you may have luck with LiFePO4 14500 cells.
They’re rated at 3.6V max, so I don’t think they would fry the camera.
(What Top Cat said.) :slight_smile:
Bort,
I’ve had the same issue w/ my older Oly SP320. It’s VERY fussy about rechargeables, I tried several different brands [none of which were EneLoops] and finally learned my lesson. I was told that the problem w/ cheap NiMH cells is the voltage drop under load, digital cameras really do present a load to any cell and some older camera’s processor will shut down if the voltage goes low. Most of the newer models are geared to rechargeables which minimizes the issue.
It’ll be fine.
My old Nikon used to complain with NiMH until I used eneloops in it.
I am using eneloops my non eneloops sit in a jar unused and almost forgotten
I don’t have any alkalines but wthen I did have some I would get 20 or 30 pictures so its not worth the cost
lifepo4 seems like a good idea I’ll look into some of HKJs tests
lithium primary may be a good idea as well I shall look into it as well
^ This
