That is pretty darn AWESOME.
Very nice work. You have plenty of heat sinking to drive those emitters pretty hard.
No. Build quality is good. All worked. I fried two playing with their PWM hookups, but that was my fault. I ordered three batches. Took about 4 weeks to deliver each time.
Not yet. Many projects in the queue still.
Actually I think the vertical beam angle could be narrower. Iād like less light on the ground in front and more in the distance, so I bought some XQ-E Hi emitters to test. With the same lenses, they should get more Cd per lumen and the vertical should decrease from 13 to 8 degrees, per Carclo.
This bar might be obsolete very soon.
Man what a sweet build!
Welcome to BLF. I canāt explain how but someone reading here certainly can tell you how to set up your high beam vs. El Jefe shots either as an alternating GIF or even cooler is the hover-over trick so when you hover over it with your cursor it switches between high beams and El Jefe. It doesnāt matter if you do that or not it just sounds cool. Anyway, well done. I love the stealth factor. That straight on shot looking into it looks awesome. Looks literally like one solid bar of light. :+1:
Itās long, thin and cute :heart_eyes:
Awesome work
Thank you for sharing
Nice light and some good welding.
Wow this is super sweet.
Great idea! Done and done.
Nice!
Way to take advice and go beyond. :+1:
The smooth transition is a very nice touch. :+1: :+1:
This is truly awesome! Iāve been wanting to do some DIY lightbar for a while now with all the available options being extremely expensive or just plain crap.
Do you have a link for the optics?
Very nice work, thanks for sharing! I am planning a similar project myselfā¦ā¦ if I ever get caught up on things.
Frankly I donāt think the $2000 light bars are all that either. Bling seems to be the primary goal over function. But then again, image is everything. No one would want to buy a plain black rectangle.
I got the optics here:
http://www.ledsupply.com/led-optics/10003-l25-carclo-lens-20mm-elliptical-spot-led-optic
Good work mate you beat me to it. Iāve starting modding a small light bar for my girlfriends car. Itās 12 inches so it sits inside the bumper. Output aim in 10-15k lumens I was going to go crazy and use XHP70s but it will cost to much. I made my own heatsink also. I am not sure about where to mount my driver.
I am more worried durability then output I think.
excellent build ā¦I run ebay cheapies they leave a bit to be desiredā¦
thanks for posting
Iām sure you can make a better light bar than what you can get off the shelf. You can space 20mm lenses and star boards 25 mm apart, so 12 LEDs in 12 inches, you can easily get 12,000 lumens using XM-L2s. http://www.ledsupply.com/leds/cree-xlamp-xm-l2-leds?gclid=EAIaIQobChMIya2939Wy1QIVkTRpCh3ohQAwEAQYASABEgInw_D_BwE
The Carclo website has beam patterns for their lenses with practically every LED available. You can get lenses for the XM-L2 in spot, flood, or elliptical and design it how you want, for example: http://www.carclo-optics.com/optic-10003l25?opticfamily=20mm Once you find the pattern you want, you can get them from LED Supply or Mouser.
Iām looking forward to seeing your build!
That looks really sleek! I like the logic behind your roof rack mount as well. There are quite a few examples of mounts just above the windshield which can cause whistling/wind noise problems and the thought of glare or the hood lighting up didnāt even occur to me. This seems like an achievable project for the DIYāers but aligning the drilled and tapped screw holes must be difficult. If you donāt mind, just a few follow up questions for you.
Can you tell us a bit more about the size and dimensions of the heat sink and c-channel you made?
Are you going to modify it in the future with any thermal management circuit?
Any plans on upgrading the current from 2A to 3A?
Any condensation or moisture problems so far?
Wow that is some awesome work and awesome pics in your post. Please let us know how those drivers hold up, Iāve been considering them for similar projects, on a much smaller scale
What made you choose the xp-g2 out of curiosity? Is youāre truck set-up with an extra battery or high-current alternator? Noticed any electrical changes or anything while running El Jefe? Thanks!
The problem is so bad there is a guy who is making a small business out of fabricating and selling custom visors for light bars: https://www.tacomaworld.com/threads/roof-mounted-led-light-bar-glare-solved.377416/
Some people even paint their hoods black.
I plan to add a low voltage cutoff to turn it off before the car is unstartable. I could add PWM dimming based on temperature, but it has enough heat dissipation to operate at 100% even in the worst case scenario (100F) weather, so I probably wonāt bother. Maybe the next version.
Most definitely. It seems to run much cooler than my prototype tests on the kitchen floor. It was on for a couple of hours in ~90F when I took those night shots and I was surprised that it barely got warm to the touch. Iām going to borrow a large battery charger and test it on the car inside the garage so thereās no air movement and up the current as much as heat will allow. Iāll rerun the power with at least 10ga too.
So far so good. I saw Gore vents mentioned on somebodyās website, read Goreās paper on the root cause of condensation, and bought one on eBay for the heck of it. Maybe it works, maybe itās a placebo.
I picked the XP-G3 for the most lumens per watt, with the desired beam pattern with a 20mm Carclo lens. I spent a lot of time on Carcloās website comparing beam patterns and LEDs. The XM-L2 is too fat. The XP-L HI is too expensive.
No, it draws about 25A, so probably no more than the rear window defroster.
You can definitely hear the idle change when switching it on an off, but thatās it.
Shot #3 made me giggle as the hill appeared out of nowhere.
