Hi Guys,
After playing with some flashlights that I tested here I started getting more and more into “from scratch” DIY. Recently I’ve been heating up my 50 and 100W LEDs. As it says in the description, I plan on using them wherever I can, but the big goal is to fit them into my car’s headlight(we’ll discuss morality later if the project will go that way 0:) ).
This being said, here’s a first test of running the LED (temporarily placed on a big radiator) at 12V, via a $5 Buck Converter from Ebay. It can just run the LED at ~110-120W before shutting down, although it gets quite hot. A 50mm fan on it and it will be ok.
I do have another buck converter available that I payed $10 for and I used that to rush 150W into a 50W LED. It didn’t even warm up… So I’ll see what I’m going to use.
As you can probably see in the video, the light output is… tremendous. At 110W this “puppy” gets out ~10.000 lumens. Although I can light up a huge area, the distance it can cover isn’t that big. Actually, measured with my luxmeter, at 1m (3ft) the output is ~4kcd (4000lux). That’s because I only used the 44mm lens in the video above, that gets about a 90degree angle. Not what you’d call “focused”.
So my goal right now is to focus that huge area chip into a smaller spot. And I managed to do that with an extra $6:
I got a A5 (12x18cm) sized fresnel lens from UK to put it to some tests. The test is a HUGE success as you can probably see in the video. Let’s talk numbers.
From 4kcd with only the 44mm lens on the LED I got 66kcd by handhelding the lens in front of the LED. 16 times brighter, not bad, huh? 8)
That spot got to about 40cm diameter at 2.4 meters away!
And another outside video. Not very conclusive, but that’s all I can provide right now.
By only handhelding the lens at 20cm away from the lens(focal point for a 12x18, 3x magnification Fresnel) I guess I was losing quite a lot of spill. So surely, by making a reflector I could get a brighter spot, no? YES!!
After making this HIDEOUS looking think (strong, white inside cardboard, testing only) I tried getting more readings. I honestly hoped to see an increase to about 80kcd (80.000lux) with it. And excuse the mess, it’s always like that when “i get going”. :8)
A few readings later… 80-100kcd! It varied because my hand wasn’t steady above it. I used a tape ruler to go 1m away from the led and scouted for the brightest spot, that got a reading of about 1050 (x100) on my luxmeter.
100kcd with that huge spot! What if I cover the inside with neatly glued aluminum foil?
Now, the biggest problem for a car’s high beam is that I don’t have 20cm worth of space to focus the light. More about 10cm. So I must make more adjustments to the optical system.
I ordered another, thicker 44mm aspheric that claims it can throw the light in a 60degree angle, and two 78mm lenses with reflectors and brackets. I honestly think that by using the 44mm 60degree lens I can focus it better in the shorter distance, but we’ll see.
The following days I hope to get some time and some help from my friends and go test it outside (along with my NASA looking reflector :D), the same place I went to test the lights in my previous thread.
I’ll keep you posted. Any feedback and suggestions on how to focus that big boy in less space will be greatly welcomed.
