Maybe they use the same screen as in the S4+ (tbh I don’t like these displays, graphical ones are much better for this type of device)
I don’t think we see an analyzer like the MC3000 here (but I don’t think this was the point of this charger shown)
The markings on the buttons could also be upside down.
The display of the S4+ is awesome (readable) but I´d like to see the state of all cells; maybe cycling values like Skyrc do.
Graphical displays are inaccurate because of the low resolution. The Xtar VC4SL have a mediocre solution, some values for all cells but it´s unreadable even at a low distance.
I don´t expect a MC3000-like analyzer but at least also a discharge function for capacity testing
Don´t believe it because the bays would be also turned. I know some chargers exist with “wrong insert if cells” but it´s rare
Sorry, I can only tell you the shape of the mold, which can charge 26800 batteries,the new product is still in the debugging stage and details such as functionality cannot be announced yet
After the product is confirmed, we will inform everyone thanks
One of the main usability issues with all chargers I’ve ever used (I haven’t used mc3000): pressing buttons to check each slot while charging is highly annoying. Need ability to display some data for all slots simultaneously. Solutions, starting with best:
each slot can show user’s choice of values.
show most important values for each slot (e.g. % and Wh).
standard display that can only show all data for one slot, but cycles thru slots automatically, ideally with selectable time (e.g. 1-5 s per slot.) Actually you want this regardless, since showing all data for all slots isn’t possible unless huge display.
Any number of ways to do this, all I know is all charger displays I’ve ever used with standard segmented LCDs as well as all pictures I’ve seen, are all bad.
Actual real values are more important than user choices. It won´t help to show you the selected current if the charger decide to use a lower current (like the charging current close before end of charging or because of high IR)
Showing a voltage is better than a % , mWh isn´t very helpful because the cells have a mAh statement.
Similar to Skyrc, but their concept to cycle all values for every slot is one of the best solution.
A state LED for every slot like with Green/Red would be also very helpful
But overall I agree, the S4 Plus have a great display but the concept of showing only the state of one cell is very annoying.
I really like the S4+ and it does everything I ask it to. It doesn’t charge 26800 which isn’t a big deal since my 26800 lights have built in PD charging. If I could nit pick for a new one though, I’d appreciate 4-5 amp charging on 26800 and an updated display with info for each bay like the Opus or MC3000 or the xtars. Please increase the accuracy of the iR also. I like the idea of status LEDs also.
For a medium price charger these 3 features alone will make buy a new one:
adjustable charging speed (0.5A, 1A 1.5A 2A)
termination voltage : 3.7V, 4V, 4.05v 4.1V 4.2V
usb-pd power input.
Nice to have: IR measurement, and deeper contact , or spring, for the positive end so my batteries with a dented + can be charged without using a small magnet.
Choosing terminal charging voltage and “storage mode” would be great, but I’ve got another feature I’d like too have in a new charger - built-in cooling fan. I measure capacity of every battery I buy + some older ones to know how they’re holding up. And when discharging 4 batteries at once heat is a problem - I use external USB fan, but my cat loves to play with it and already destroyed one I know there is one such charger (4 cells + fan), but it’s expensive one - would be great to have such feature in let’s say 40$ charger.
Something I think the current market is missing is a 100W PD powerbank with field-swappable cells. What I have in mind is heavily inspired by the Xtar PB2 series, but with four cells and up to 20V/5A output to power laptops.
Four cells - up to protected 21700
Graceful degradation of performance with fewer cells (though two high-drain cells are theoretically enough for 100W output)
Graceful degradation if cell voltage drops faster than expected/safe
A latching or magnetic cover
Reasonable handling of mismatched cells
Support for the full range of PD voltages under 20
