Does anyone know LED 3030(Size), 3 volts, 140 to 200 mA & CCT 6500 ±500?
Digikey, Mouser, Arrow Electronics… etc.
i want 0.5watt led. have searched digikey, find noting.
You might be driving it at 0.5W watts but they can probably handle more.
You just need the right tint and form-factor.
There are many 3030 that are 6V.
A 3V 3030 would be Seoul Semiconductor STW8C2PA
what is the application?
we want to make Omni-Directional LED Light Bulbs (Total LEDs wattage=10.5 means 21 LEDS each 0.5watt)
You mean like those ebay corn lights? You can buy one for about $3, just FYI.
Why 3030 may I ask? I have a couple of these bulbs, they’re 5730, and pretty cheap. The emitters pretty much fit your requirements except for the smd size.
http://www.ebay.com/itm/400761382537
Hello,
If you can see Philips LED Bulb (12.5W E27 220-240V 1055 lumen),
they are using 3030 LED 0.5watt, 3volt & CCT6500k. they are driving it at 150mA without any difficulty. There are 21 LEDs in series 65 Volt means 65/21= 3.09V
Philips is using this LED (12.5W E27 220-240V 1055 lumen)
Philip LED BULB
