…aaaaaaannnnddd… The mail delivery driver showed up late yesterday evening, but I finally got the light!
…and then was in a hurry to leave this morning, so I forgot to bring it with me for photos… :weary:
I received the light in great condition, in a “BLF Special Edition” box. Opening the box, I found the packet with the kit, including two spare tailcaps, and replacement O-Ring.
The light itself underneath, was impeccable! Spotless, no dust, fingerprints, or imperfections to be seen on the reflector or coated ( :sunglasses: ) lens. The XP-L HI emitter, perfectly centered in that flawless reflector is a thing of beauty. The Anodizing and lettering (BLF Special Edition) were perfect. Mine did NOT have the Old-Lumens inscription, but I am 100% okay with that; I am a light user, not a light collector, and I would feel guilty carrying a limited O-L version…
All I had was my 3+year old Trustfire Protected cells, but I couldn’t resist, and dropped one in the light. The protected cells fit the tube perfectly, and I was greeted by a glowing blue tailcap. I then patiently waited until full darkness outside before powering the light on.
After watching Broken Arrow…
…and enjoying some homemade fajita chicken quesadillas, I was ready to check this light out.
The only other pocket throwers I’ve had are my older Romisen RC-G2 (somewhat modded, but severely under-driven; I should work on updating this light…) and my more recent Convoy S2 (full size model, 3A Qlite, deep SMO reflector, 1A XP-G2).
Vs. the S2, this light, with its larger reflector and FET driven XP-L HI, wins on power-on with a brighter hotspot. The hotspot is wide, and fades out irregularly, while the S2 has a much more defined central hotspot, with less spill due to the smaller emitter. Unfortunately (and I strongly suspect, due to my older 14500s), the output on the X5 drops off, quickly becoming dimmer than the S2 with its newer high-quality/high-capacity 18650 cell. This isn’t due to the Turbo drop-out either…
Bumping the modes (I think I counted seven?) this light goes from a moonlight/firefly low (I thought the light was powered off at first) to the blinding high. The low mode was especially interesting, as I was able to stare directly into the glowing emitter and examine it closely, without any discomfort. Even at this low level, the reflector gives a useable hotspot, providing your eyes are sufficiently night-acclimated.
Now, I need to buy a set of the high-drain cells and test this light out fo’ realz.
This is an awesome, light, it’s obvious no attention to detail was spared in the construction. Top-Shelf stuff here, great work Manker, and for an even better cause!
