After tearing the light module apart, I put off doing anything with the Tiablo ACE.G for awhile. From the beginning, I thought that the light was way too underpowered, from the brightness standpoint.
So, today, I finally got up the nerve to actually do something about it.
Parts:
- XM-L T6 on a 20mm PCB
- Generic 8*AMC 7135 driver (https://www.fasttech.com/p/1127403)
I kept reading that I should use heavier gauge wire to connect the driver to emitter, so I got some 20 AWG teflon wire from Ebay.
In the end, I was able to get this done, but using the 20 AWG wire made the job way more difficult (to me). It was very stiff, which made stuffing the extra wire into the Tiablo module difficult, and it even caused one of the solder joints on the driver to “pop” off. Also, just soldering that thick, heavy wire onto the tiny pads on the PCB was a real pain.
Also, with the thick wire, I couldn’t get the original insulator disk back on, because of the “lumps” where the solder joints were.
I didn’t want to glue the emitter PCB to the module, so what I did was put some Arctic silver under the PCB, lay the insulator disk over the emitter/emitter PCB, then carefully screw the head down on the module. I had to try that a couple times because the emitter kept going off-center.
I was finally able to get it done, but even then, the emitter is a little far back from the bottom of the reflector, but I’m not sure what I can do about that.
The driver that I mentioned above fit into the opening in the Tiablo module, but it wouldn’t stay, so I had to solder the driver to the module.
One thing is weird. That driver is suppose to have modes, but after I put everything together, it doesn’t seem to have any. I’m guessing that because of the problems that I had soldering the thicker leads to the driver, that I may have a bridge somewhere.
I’m waiting for dark now, to try it out, but it looks pretty bright :)…
Meanwhile, here’re some pics (they are UGLY!!):
Edit:
Beamshot - sorry in bathroom, and I couldn’t move far enough back):
Is this good (it looks nice to me, though) ?
Edit 2: BTW, tailcap current is slight > 3 amps…
