Hi BLF!
I have some doubts about components, and other things, to engage at least 2 mods. If you can help me on these, please let me know ![]()
1st mode – Sofirn SF10
I wanna turn my Sofirn SF10 in a different light, mainly due to its driver (H-M-L-ML + Strobe) and PWM it has.
It uses a XP-G2 R5 NW LED, and I wanted to keep it that way!
The main mod I wanted to do – so far – was to use a Biscotti driver 8*7135 in it. My concerns are:
a) the use of that biscotti driver with the XPG2 Led – will it damage the LED ?
b) the use of biscotti + XPG2 with a 14500 battery – will the battery get over drained and eventually not work correctly?
Any leads on this would be helpful! Thanks in advance ![]()
_
2nd mode – Convoy S2+ triple
I want to make my first triple light and need some suggestions about components, or at least some guidance on which to choose!
I want a light that can hold on High for a while without getting extremely hot, obviously floody, but if possible with some throw (despite triples are floody…), and with Neutral White tint.
Therefore, I’ve made some search and found some components. Considering the above mentioned specs I want, please help me to chose the best to match those requirements. If you have other suggestions, let me know please!!
These are the defined aspects, so far:
a) Host: Convoy S2+
b) Driver: FET + 7135 Driver - 17mm - MTN-17DDm (with Crescendo) FET + 7135 Driver - 17mm - MTN-17DDm
NOTE - One doubt about this driver: will it work with forward switch?
From now on, I’m all doubts, so I appreciate some help on these options, or others that you can have.
PILL / SPACER :
1) Copper Triple Spacer for Convoy S2+ Hosts - XP-L / XP-G2 / Nichia 219 -
2) Copper spacer for Carclo triple Convoy S2+ - (Low-cost copper pills, spacers, optics, drop-ins (Updated 23/10/2022)))
3) Copper pill triple Convoy S2+ - (Low-cost copper pills, spacers, optics, drop-ins (Updated 23/10/2022)))
EMITTER :
1) CREE XP-G2 S4 3D - (3) CREE XP-G2 S4 3D LEDs on NOCTIGON 3XP COPPER MCPCB + PRE-BRIDGED
2) CREE XP-G2 S4 3D LED - http://intl-outdoor.com/noctigon-3xp-mcpcb-cree-xpg2-s4-3d-leds-p-848.html
3) Nichia NVSL219C D240 4000K 90+ CRI - http://www.mtnelectronics.com/index.php?route=product/product&path=60_94&product_id=839
4) Nichia NVSL219C D280 5000K 80+ CRI - http://www.mtnelectronics.com/index.php?route=product/product&path=60_94&product_id=592
5) NICHIA NVSW219BT-V1 R9050 D220 - http://intl-outdoor.com/noctigon-3xp-mcpcb-nichia-nvsw219btv1-r9050-d220-p-797.html
6) NICHIA NVSW219CT R8000 D260 - http://intl-outdoor.com/noctigon-3xp-mcpcb-nichia-nvsw219ct-r8000-d260-p-910.html
7) Triple LED lamps with MCPCB for E2L - Page Not Found - Aliexpress.com
8) Triple Cree XP-G2 4500K - 10.75€ 6% OFF|Triple CREE XP G2 LED SMD 3535 Emitter mit KDLITKER 20mm DTP Kupfer MCPCB Parallel mit Optik Taschenlampe DIY|led emitter|neutral whiteemitter led - AliExpress
OPTICS :
1) 10507 Carclo Lens - 10507 Carclo Lens - 3-UP Narrow Spot Optic
2) 10511 Carclo Lens - 10511 Carclo Lens - 3-UP Frosted Narrow Spot Optic
3) CARCLO 10507 – http://intl-outdoor.com/carclo-10507-triple-led-optic-lens-p-836.html
4) 3-in-1 20mm Optical Lens - 4.69€ 6% OFF|3 in 1 20,1mm (Dia.) x 8,2mm (H) Triple Optische Linse (1 pc)|optical lens|lens 20mm20mm lens - AliExpress
5) Optic Lens for E2L - Page Not Found - Aliexpress.com
These are the things I found that I can be using to the mod. Please help me on this to make a nice “combo” and to get a nice triple flashlight!
Thanks in advance for your help!! :+1:
