DQG Hobi Ti 450nm Blue Laser Osram PLTB450B - OFBD - 10280 - Momentary Tail Sw - 1600mW.
Made from a DQG Titanium pill capsule with Ti extensions & hand made copper parts, a little pocket monster :D
Osram PLTB450B 1600mW 450nm 5.6mm TO56 Diode
3-Element collimating glass lens assembly
9.5mm x 0.7mm ARC protective glass
Copper diode housing & heatsink
Head twist focusable
Upgraded focusing spring
Silicone compression focus O-ring
1600mA adjustable potted single cell boost driver
Brass lined body parts
Magnetic momentary tail switch button
Blue GITD glow inserts
Magnetic tail & keyring holder
Max - 1600mW, 1.6A/2.5A (Around 1120mW OTF with 70% efficient 3-E Lens)
Length - 79mm
Width - 12.7mm
Weight - 35g (With 10280 cell)
The centre glow part in the tail is the magnetic momentary button, surrounded by an 8mm x 4mm neo ring magnet.
Some of the different laser colours available.
Osram PLTB450B 450nm 1600mW - Data.
FAA Visible Laser Hazard Calcs for LSF-v02
Wear appropriate safety glasses kids 8^) :THUMBS-UP:
CRX DQG Titanium 10180, 10280, 10440 Pocket Charger/ Spare cell carrier.
This titanium spare cell/ pocket charger can carry and charge an extra 10440 cell for more power/ longer laser run times and being modular can also charge 10180, 10280 cells.
The section with the brass rings can be used to extend the laser to use a 10440 cell and the remaining sections will still house the 10280 cell.
