Ah! Ok! I knew people were doing the P60 pill method of putting in drivers and couldn't remember why (thought it was due to a 20mm mount space). Now I remember it was due to not being able to solder to the aluminum pill.
If you were planning on stacking extra chips on the driver anyway, just go with the Nanjg 101-AK. Same programming and chips as the 105C except all components are on the topside and it has a flat base like the original East-092 used in the HD2010. Only has 4 chips (1.4A) but I've stacked onto each for 2.8A in the past and there is no reason you can't add even more. Retaining ring will thread right on and you don't have to booger up the stock pill by modding it.
Not sure. Where did u see that? There's 1A, which is a tint - cool white. Unless someone meant "max amps", if so, CREE rates max amps at 3.0A for the XM-L's, but we like higher ! Some feel going over 3.5A is not worth it. I'll go to 3.8A if I feel the pill and adjoining flashlight body can handle the heat, sometimes higher, but always with a U2 or U3. My HD2010 is at 4 amps - no problem, but I beefed up the pill and there's so much mass with this flashlight. And I "think" the U3's can handle higher amps better than a T6, so I went with a U3 1C - should be little more lumens as well.
Definitely for the HD2010, at least 3.8A. Still want to mod mine up though -waiting for copper stars from Nitro, then got an XM-L2 U2 to go on the copper, then in the HD2010 -- can't easily do much more than that (well - also have a UCL lens in it ).
Oh - so you were asking for max amps? Like I was saying, there are different opinions, different options. That I-O driver linked by fonzeka seems almost perfect - it's got a clean back-side, basically 17mm so should fit stock, it says 4A but guys measured 3.8A max, it's got some crazy programmable mode setting UI, or you could go with the 101-AK driver JohnnyMac recommended and add lots of 7135's, going triple decker (I used that driver before up to 2.8A), add 6 7135's: 3.5A, 7: 3.85A, 8: 4.2A, and it's got a nice 3 mode option.
Well ... Here's where it gets dicey. The HD2010 is considered direct drive, better quality battery at full charge, more amps. With my stock HD2010 and Panasonic 18650 2900, I was getting 4.6A. So using a regulated 4.0A driver, I'm actually putting in less amps, but the light will maintain the higher power better and not be so dependent on the battery type and it's charge state. But now, I can safely use a quality 26650 and not worry about things melting (with a King Kong 26650 I got as high as 5.8A).
Don't be surprised -- there's no "wow" effect when updating this light to a regulated driver, as there are with other lights that are under-driven.
Not with a true regulated driver, just longer run times because of the higher capacity of the 26650's. With some lights/drivers, it does make a difference.
"The Bopper" - she's a reseller on eBay that Old Lumens has been using and recommended -- prices are very good and service/support outstanding. If she doesn't have what you want, simply leave her a message and she'll get back to you. This is her store: http://www.etsy.com/shop/Bopper.
Doesn’t everybody know about Solder-It? Not just for their standard solder paste but they also have a solder paste to solder aluminum to brass/copper/aluminum….or so they claim. Just wondered if anyone had tried it. Sure could solve some problems if it works as they say it does.
