Driver for xhp70.2
Hi guys, someone of you can help me about the driver i need (just a simple one) and how to connect 3 (or 4) XHP70.2? Regarding the battery pack I would like to use 3 18650 batteries in series connection.
Hey mate welcome to BLF.
How many amps are you hoping to get out of the driver? For highest performance it would probably be best to go with 2s 18650 and use a direct drive driver. Or 2s and 2p?
Not sure if many buck drivers that can output high current woth 4 XHP70.2s you would want at least 20amps?.
Your best bet is to go with something like a FET driver. Mountain Electronics sells either 1S or 2S-4S input FET or FET+1 drivers. I have the 4S FET driver and it’s nice. You can run xhp70.2 on 6V or 12V. doubling the voltage halves the current. If you run them in series at 12V off a 4S li-ion or lipo that’s a good option for lowering the currnent. At 2S, you’re looking at monster current from 4 of those emitters. Lexel on this forum sells nice drivers for just about anything you’d need, and since you’re in Europe I think that’s a good option too.
thank you guys. Sirstinky do you think this:
http://www.mtnelectronics.com/index.php?route=product/product&product_id=888
it's the right driver?
so if I want to supply the driver with 12 volts, i just have to take the series of 4 18650 right?
and about the connection of the 4 LEDs xhp 70.2 how do you suggest me to make the connection?
(I'm so sorry but i'm a very beginner about all this stuff!)
The more I ponder it, I’m seeing this is is a fairly advanced build. To get the 4 xhp70.2 to work, you’d ideally need a quad mcpcb. Look on Aliexpress or Banggood for one. You maybe able to make that driver work, but I think your best bet is to use some kind of a cc/cv boost driver that boosts the voltage. The amp requirement will be high so you wont be able to run them at max p You will also need high drain batteries (or a battery pack) and a big heatsink to handle the heat. TaskLED makes really nice drivers for that, but they’re kind of expensive. You might get away with a cheap one from eBay as well.
thank you very much sirstinky, i agree when you say “The more I ponder it, I’m seeing this is is a fairly advanced build”…maybe also because this is my first attempt, I’ll try with just a single XHP 70, powered by the series of 2 18650, with a driver like this:
https://asflashlights.com/-diy-parts/75-10-amp-capable-17mm-led-driver.html
I hope this is the right configuration!
I think you will be really impressed with it. Start small and see how it goes. Make sure your batteries are high drain capable of 10-15A because Matt’s driver at 6v on the xhp will easily pull 10A and more. Texas Ace tested an xhp70.2 to over 10A on direct drive.
i only have to find something that lets me to control the percentage of power. Do you have something to recommend me?
The driver controls the output through the modes of the user interface. You control the user interface with the switch on the light. Matt’s driver comes with Dr Jones UI which is one of the more comprehensive ones with tons of modes amd profiles. He dis a youtube video on how to use it, just look up adventure sports flashlights on youtube and you should find the tutorial
ok, because i was not sure that that driver has the button to change the mode…’cause from this:
it seems that there is only the driver without the button, isn’t?
The button/switch is in the flashlight. The driver has to be installed in the flashlight or connected to your power source and a switch somehow.
ok, so a part from this:
what i need to control the power?
because i know some driver have already installed the button to change the mode, but from this
you mean i have to install some switch on my own? can you suggest me something?
You’d need to connect the driver to a battery (negative to the ground ring, positive to the center contact) put a switch somewhere in the circuit. Then connect the driver output to the led. That’s good for testing, but long term you need to figure out a solution for keeping the driver cool if you run it at high current.
Perfect! so i already have a suitable led flashlight, i just have to modify the battieries, then substitute the led and add the driver, there is already the switch (ON/OFF) at the bottom of the flashlight, so I don’t have to add the switch! (for sure it’ better to not make a protract use at the 100% power)
thank you very much Sirstinky, if I’ll manage to complete my work I’ll post it here!
Great glad to help! I’d like to see it when you’re done.
