Ledsmoke, ryansoh3,
Probably it depends on what 18650 are used. My best ones for now are Samsung protected ICR18650-26f.
With the driver installed in the Trustfire TR-j19 flashlight, on 3 dedomed noctigon XML2`s I got a tailcap reading with the fully charged Samsung`s of 3,8A on turbo. I am still waiting for the 32650 trustfire`s to arrive.
ImA4Wheelr,
Thanks! Yes, it looks like you could shave 1mm from the new driver to fit the ZY-T08. I do not know what other lights will fit, but there is always a lathe and the possibility to machine a fitting ring
Hikelite,
I am using the driver on XML2`s on noctigons, from what I know they are direct thermal path. Just for fun, I directly connected the 12v lead acid battery to the TR-J19 head and the increase of light output from high( 3,4A each led) to turbo (6,2A each led) was amazing.
18sixfifty,
Thanks, I am sure you will find good use for those little monsters
ryansoh3,
It`s about the 85T03GH transistors, Flomotion provided the ebay link for them.link
zeremefico,
Nice work ! It would be nice if you could provide some details about what resistors do you stack, what values and witch one did you jumped(wire mod).
bibihang,
Yes, cooper braid on the springs makes a huge difference on direct drive and high current.
comfychair,
My Dry driver was shipped 2013-12-30, when ordered(2013-11-28) the page had the old driver pics. I just received the new 32mm version.
