This topic is about the driver that is found in the DRY flashlight 3xCREE XM-L T6 link
This is a extreme driver being capable to run 3 XML`s in “series” at very high current.
I has 4 modes : low, medium, high, turbo. On turbo is known to be direct drive.
I burnt the transistor after I connected it by mistake to 3 xml`s in parallel.
Not being able to find what was labeled on the original transistor I began to test it with different transistors I found on old computer motherboards.
Finally, I was happy with a transistor from Advanced Power Electronics Corp. the one labeled 85T03GH link
After installing the new transistor, the current on turbo mode was around 6,2 amps at the leds !! I used a 12v lead acid battery as a power supply. The other modes are :
Low : 0,25 A
Medium : 1,30 A
High : 3,40 A
Turbo : ~6,15 A
The mod was a succes, interesting the driver does not even get warm on turbo ! It means that with the new transistor it is also very efficient ( RDS (ON) 6mΩ )
Here is a video link for the test : DRY driver test
It seems that now, cnqualitygoods sells a different version of this driver, the board size increased from 24mm to 32mm. new dry driver
