I don’t intend this to fufill anyone’s wish of a tint ramping UI (cause I’d like that too!) but I did make this thing. Two drivers, both running anduril, two switches and 2 LED’s (Nitecore CR6 host).
P.S. This is [unintentially] my longest running flashlight project, started 3-4 years ago then walked away from the hobby, came back this summer and just now finished it up. I started if after JohnnyMac sent me his broke Imalent
That’s pretty cool. For tint ramping on a single driver though, the lantern branch has that implemented. I’m waiting for actual hardware and more development before I merge it into a bigger branch though.
It seems to work fine in my tests so far, but the hardware I used has a pretty non-linear PWM response curve so the linear mixing doesn’t quite hit the levels it aims for. I’m hoping the production hardware won’t have that issue, but if it does, I might try to make the mixing compensate for it.
I’m trying to stick to build targets for actual production lights, instead of including hypothetical ones.
I make build targets for lights I have, and I don’t have anything like that. In theory, I could make a config based on detailed specs, but I don’t have that either.
If you have one you want to support, it should be reasonably simple to write the build config file. Copy/paste parts of other configs and tweak the numbers inside to calibrate it.
I did modify the GT configs to make it working with ramping
and there is again the problem tweaking the voltage readout
that voltage fudge factor –15 makes the firmware go wtf I quit, and a 182k over the 47k is not really a nice solution
Hello guys. I’m new to the flashlight game and I have a Sofirn SP36 still shipping to me. After some research, it seems like Anduril is much better than the stock firmware. Would anyone help me explain how do I flash it to my sp36 when it’s here? What tools do I need?? Thank you so much
Been looking at the voltage monitoring code (fsm-adc). I assume you want to do good old voltage divider readings, so USE_VOLTAGE_DIVIDER must be turned on, then the VOLTAGE_FUDGE_FACTOR is irrelevant.
The voltage divider readings is scaled based on ADC_22 and ADC_44, which I assume have to be set according to what resistors you use.
You could probably copy the values from NarsilM.
I'm not sure if anyone tried it this way? Looks like the old voltage_blinks[] arrays in tk-voltage.h are not used in Anduril because fsm-adc has it's own copies. I dunno if TK or others ever tested/used this with external voltage divider resistors?
The "stock" firmware is NarsilM, v1.2. Updated version than what came in the Q8, same baseline as the BLF GT. The UI mostly got outstanding reviews out of 100's posted between Amazon and Banggood on NarsilM, not to mention many accolades in video reviews, so it can't be that bad? Slightly better than the "lo-med-hi-strobe-sos" of an UltraFire?
But if you still do wanna upgrade, first challenge is getting access to the driver, then you'll need the programming clip/USB cable, then the latest hex file, probably from here: http://toykeeper.net/torches/fsm/?C=M;O=D. We mostly use AVRDUDE to do the download. There's some really good info already here on BLF somewhere of how to get the cable and software tools you'll need - hope someone else can chime in.
Ahh I see. Yeah it’s NarsilM is much better than simple old style control haha. Anyways. I’ve heard that the sp36 has glued board? And thanks for your answer !!
As I said two weeks ago, and as Tom said just now, the fudge factor is not relevant for a light which uses a voltage divider. Use the voltage divider method instead, by setting USE_VOLTAGE_DIVIDER… just like in the BLF GT cfg and hwdef files.
I had already the voltage divider activated from GT cfg
But at 3V per cell it reads 3.7V on the blinkout
the voltage fudge factor works to –10, but at –15 the voltage readout blinks 2 times then bugs out
I also wrote that the ADC values in the GT file do not change the voltage reading at all
those lines do not work I dont know where it takes place that the voltage reads so I could modify it
this bugs out the voltage reading, and i can not find any TK voltage file or so which calibrates the readings
