Hi
I have got SANYO 18650 2600mAh Rechargeable Battery with Protection Board
would these be ok to use with this torch or should i buy LG DB 18650 MH1 Li-Ion 3200mAh 3.7v PROTECTED BATTERIES. Nitecore i4 charger
Out of those two the LG MH1 3200 would be best, the Sanyo will work but the discharge rate appears to be quite low (Continuous Discharge Current: 2.6A) as opposed to 10A continuous for the LG. This flashlight can pull slightly over 3.5A. So you probably wouldn’t get the full brightness potential with the Sanyo.
Does this seller offer a BLF Discount?. Also, I’ve never purchased from Ali before. Is there no PayPal ? If product doesn’t show up, any protection? Thanks
No further discount that I’m aware of. Prices are good tho.
No PayPal, pretty sure someone confirmed before? (You could always just message them on the site and ask to be sure)
I’ve been using their payment system for years, I’ve never had any problem with it.
Also, I would recommend selecting ePacket shipping method. It’s much faster, less worry and better tracking. Message them and ask if they can include it.
Just an update over what I said: the tailcap of this X6 IS interchangeable with the BLF X6’s tailcap. Every part legos just fine. The threads are different between the two model lights, but they are able to be mixed and matched.
Very Helpful, Thank you. As a side note, I have one X6 from Gearbest and it is very nice. Apparently it has a diff reflector, than the one from the OP. I want to get one from the OP Seller. I’ll report back with a comparison. Thanks again.
Thank you gusta, at least I know that package was sent 45 days ago. I will wait couple more weeks since seller have prolonged buyer protection to 100 days !
Ha ha 100 days enough to go to the moon and back
have this light for a while.
can say really please than expected.
small form factor, throw & brightness on par with my XM-L based light driven roughly on 3.5-3.8A with 50 & 60 mm reflector.
I keen to see XP-L HI on large reflector or multiled.
the only con is the clip, unusable to me. remove it for better hand grip.
