Yes, that should work. Great tint and will work well in this light. So, good choice! Are you going to give modding it a try? If you’ve got an iron I would so go for it. Outherwise I’m sure someone here will swap it for you.
You can always get the X5R which is available in xpl hi. I have both and the X5R is like an upgraded version of the X2R. More output, plus a forward clicky! It also has more of a SMO reflector. There is a tiny bit of texture, but the hot spot is very defined and the throw is noticably further.
If you want to build a custom driver though, you’d need to stick to the X2R as it’s a different design to the X5R.
By size, you mean the length? Yeah, the X5R is about 3/4 inch longer. I honestly don’t notice the difference.
I tend to use my X5R on turbo almost exclusively so having a rear switch that is on/off only is more simple in my opinion. Turning it on briefly with a half press is a definite advantage.
Anyway, I have both right here if you wanna see a beam shot comparison or side by side length difference. Just let me know.
Do you currently have an X2R with a TIR? Interested in how it performs and looks.
Not sure I’d want to go that route though, I thought I read here about some pretty poor efficiency with a TIR which can be upwards of 20-30% in some cases, but I’m a novice on the subject. Would it not also cut down on the candela of an XP-L HI, negating the advantages of it?
Yes I was talking length. Given that I’m looking to carry the X2R in the course of my work the shorter length is a factor. But the X5R coming with smo and the emitter I want is certainly tempting.
A beam shot or any other pics of the two would be great.
Okay, it was hard to capture the reflector texture, but the X2R is real OP, the X5R is barely dimpled. It’s also deeper than the X2R. This makes the hotspot smaller, more defined and throw further. Both use xm-l2.
My X2R is neutral white and my X5R is cool white so that makes the X5R a bit brighter. The higher output of the X5R also adds to the brightness. It’s really in the distance where you see a big difference.
For long distance throw I already have my TN4A XP-L HI nw (which I use to spot addresses from the street in my work), so I’m not necessarily needing this light to be the especially powerful/throwy one, mostly a slightly tighter beam is what I’m after. I think an XP-L HI in either one (even with OP reflector) will more that suit my needs, which for this light will be short to medium distances. Given that any of these lights are overkill to be honest, I lean towards the more compact and streamlined X2R right now. Well, I already purchased it days ago, so I’ve gone past leaning
If you can use a soldering iron the change is pretty easy
Unsolder leads
Use a screw driver to lift the old board which is mounted with soft thermal glue
Remove all thermal glue from head
Apply a 2-3mm big blob of good thermal paste like Arctic Silver 5
For the LED Gasket there are 2 options
Get a XPL sized for Convoy S2
Or
Glue the XML2 one on the star
When you get another LED also a AR coated 21mm lens should be nice to gain about 9% output in the hotspot
I’m sure it’s easy and the process will become clear once you’ve done it one or two times, I’m just a little hesitant to make the X2R my test case, as I need to use it and work properly. I would rather purchase some throw away parts to learn on I think.
triple wont fit without serius work with a Dremel or saw
the diameter of the head is about 18mm and thze MCPCB is about 10mm deep inside,
you may cut some 4-5mm off the threaded tube on the head might be enough for a spacer that is 18mm in diameter and gets to 16mm down where the star was, as the base is not flat
and grind some of the inner part where the legs of the optics sit
and grind the MCPCB down to
