Hi guys. I’ve been away from these forums for long and it has been good for my wallet!
I just saw self built post a review of new eagle tac models (im subscribed to his youtube channel) and man the new models got me drooling…
The SD10 is about 300 lumens dimmer, but takes a D or 32650, and costs less than half as much. It's currently available at hkequipment and one other shop I can't remember. It's on request at Fasttech. Should I add you to the list?
Do you see it in the tech specs? I don't. I only see 14500's and AA's. It's like a cross between the Nitecore EA4 and Trustfire TR-A9, except it takes 3 cells instead of 4.
I have one and I like it much better than the Nitecore EA4. I had two EA4 lights I gave to family and friends with Eneloops and a charger.
the GX25A3 is compact and well made, especially the indexing cover that eliminates rotating contacts. The UI is fine for me, I have it set to come on the low mode. IMO, the only interface easier to use is the Nitecore Sens CR. It feels a little heavy in the hand. I have not noticed the parasitic drain like the EA4.
My light came with a plain end and a second one with a second button switch that is handy if you prefer an end switch and it has a momentary contact mode.
Same. Except I got rid of my 3 EA4’s (1 CW AND 2 NW’s) and have the GX25A3 on order. I couldn’t get over the randomly different parasitic drain, sometimes they would last weeks or longer unused (especially the one I kept in our bedroom window would go forever without being used) and other times it (they) would drain fresh batteries overnight. In fact the only time I ever saw a NiMH completely drain and then reverse charge was in an EA4, it came out at -.21v, THANKFULLY they didnt take Li-ion, that could have been a “vent with flame” inducing event.
I really like the look of this light and contrary to most I think the 3AA (vs 4AA) is actually a good thing, in an emergency, have to scrounge up batteries situation, only needing 3 could mean the difference between a working light or being in the dark.
Why has the price of the GX25A3 not dropped any from the release several months ago? The EA4 and the D40A both showed up and within months could be had for 30%+ below MSRP, from what I can find this is staying steady right at$95. What’s up with that?
