Easy quad-carrier
Inspired by this and this I was surprised to see few posts about simple multi-flashlight carriers, considering the potential throw they allow.
Here was the simplest idea I came up with.
This post is pic heavy!
First off some of the parts used in this post (some affiliate links included):
360 Degree Rotation Cycling Bicycle Mount Holder Clamp for Flashlight Torch
Cheaper in bulk here
Haven’t tried it but this mount could be even lower profile
Higher profile
I used four mounts to connect four P60 hosts in a loop so to speak.
SF L2N, extensions
2 x 502B (the red can be found at lightmalls with emitter bundle, but if you contact them you may be able to specify what drop in you want)
501B
Generic 12V xenon
KD XT-E warm white
Generic red, green
Having at least one of them longer than a standard 1x18650 host will help you with holding the bundle of lights. Here I am using a cr123a extension (this is the perfect length for the L2N imho 0:) ).
As shown in the bicycle mount description this is a 360 swivel mount, but the rotation is resistive enough to not be a problem. One of the ends is bolted and the other open, but in a configuration like this there is no worrying about a light slipping out (it would have to slip off two mounts angled 90deg). Being able unloosen one bolt and slide out a host makes maintenance of this carrier a really simple affair.
On the whole the carrier is strong and quite well aligned. The main problem with this quad configuration is that inlined mounts turn out to be parallel to each other, so if you squeeze the ends it will flex. The distance from center to center is around 4.1cm, so you can use that to determine what size hosts will fit. Two C8 sized lights will fit in the opposite-diagonal mounts.
You can’t of course expect alignment to be perfect, due to the swivel design and flexible plastic used for the open end. Someone experienced with beamshots can try it over a longer range and show their results maybe. More mounts would equal more rigidity, but for 1x18650 hosts there is clearly a limit to how many you can attach. This is the biggest limitation of using these kind of mounts as a multi carrier. Also, if one needed single switch operation I imagine you could mod four pressure switches together quite easily.
I tend to hold the bundle from one side:
It seriously reminds me of the view from an FPS game.
I put this together using whatever P60 hosts I had on my desk. As it turns out this was the combination
Allowing for a nice comparison with my new TR-1600 style RGW light :slight_smile:
Alternatively with a 18650 battery extension it can be held this way:
This grip can be made more comfortable if you squeeze the configuration into a diamond
At the top and bottom of this photo, you can see the length of the bolt contacts with the adjacent mount to precisely lock in this shape :slight_smile: making it the most rigid…
Quad-carrier beamshots at roughly 2m, -.7EV and –2EV [![](http://files.diamondsky.org/images/glow/flashlights/quad/DSC02339_resize.jpg)](http://files.diamondsky.org/images/glow/flashlights/quad/DSC02339_resize.jpg)
TR-1600 RGW -.7EV:
Quad-carrier red+green only (this red drop in is fantastically focused, green is typical for generic drop in):
Using the forward/reverse clicky this makes it super easy to compare beam shapes, it’s like a having mouseover in real-life :slight_smile:
No beamshots of a cool white configuration but it is nice to be able to mix in a warm white to cancel some of the flat spill.
[edit:] 2 x WW, 1 x CW, 1 x R is my new favourite ;
I really love the colour-separated shadows these lights can bring out. Very psychedelic :wink: Red+green:
I plan to make a custom carrier to fit >5cm diameter lights, and if people have bright ideas let me know =) I’ll post it and some other simple mods later in the year
So now you all can stop complaining you have too many P60 hosts :slight_smile:
Thats pretty damn cool actually
I like the multicolor/multishadow shots too. :slight_smile:
I love these!!! :bigsmile:
Hey instead of red-green use red-blue and find some old 3d glasses.
Oh and I like that tr-1600
nice! forget big lux, just make a VR thrower and be done with it forever! bringing new meaning to focus at infinity :wink:
i was absolutely smitten when i turned it on and it could fire all emitters at once =) lovely makeshift warm white!
oooh… awesome idea, hmm… 4 or maybe 5 C8 XM-L2… that would be an awesome sight :wink:
My first big lumen light was 7 tank 566's and a rubber band .
One in the center and six surrounding it ...it felt pretty good in my hand ...
unfortunately that was also the day i realized 1200 lumens wasn't really all that bright compared to 200. It has to do with how we perceive light ....logarithmically
but it looks cool
cylindrical lights definitely have their advantages :stuck_out_tongue:
a good thing about these adjustable mounts is that you can combine different sized lights, which does make it slightly easier to test our thirst for big lumens :wink:
what got me started into host collecting was the idea of multi-rail mounting them to my airsoft gun, yes partly for practical purpose, but partly for… silly looks :ghost:
Nice. That rig looks fun. I imagine the p60 reflectors are deeper than most of the multi-emitter lights out there. So you probably get better throw.
the hotspot is definitely smaller than the 6 x XR-E TR-1600 i compared above
P60s will only take you so far though, so i’m thinking what daylighter said!
