Hi, i charge all batteries by the torch and not with normal charger.
The good news is the batteries all fully charged in 3 hours and 10 minutes.
The bad news is the voltage… 4,22V per cell
Batteries are Molicel P42A
I think is not good and i don’t know how is dangerous.
Any help or comment are appreciated.
Small problem. Battery life can be shortened but not really going to harm the cells. Voltage after an hour is probably going to settle to 4.20V. I prefer to externally charge my batteries on a charger I’ve measured before.
The first question is… I have calibrate the voltage (it’s not correct). In the next charge I will find correct value or not?
The problem is i haven’t 4 bay charger so i have to wait 6 hours for all the battery… it’s long time
Not sure of what you are asking. I measure voltage out of the charger then about an hour later if I remember. Most cells drop a little after being charged. After I’ve used a charger for awhile and know what that particular charger does I just pull them out and put them in. 4.22 volts isn’t good but it isn’t that bad. 6 hour what not bad it takes longer to get dark again.
Thank you, but I want to know if the flat top ones work on the EC06 as I have access locally to these ones. I know The Molicel P42 work, it is longer than the Samsungs, and I am hoping the same happens for for the flat top Vapcell.
