EDCPlus / IS X60L3 Triple LED P60 Dropin ( High CRI / Neutral White )
hi there,
does any modders have this drop in already ?.
also does one LED just give like 150 lumens if it was just on its own ?.
then there is a better reason to maybe have 3 right?.
thanks kindly…
EDCPlus/IS X60L3 Triple LED P60 Dropin (High CRI/Neutral White)
$74.99
EDCPlus and Illumination Supply have teamed up to bring you the X60L3, a triple LED dropin that is low on cost, but doesn’t skip on an ounce of quality! The dropin was designed with the user in mind, and comes in a diffusor/head tool case, and even an AR lens to maximize the output from the dropin. Unlike competing dropins, the X60L3 has been tested in an integrating sphere and is compliant to the ANSI FL-1 test. The LEDs - 3 Nichia NVSL219AT-H1 , are being driven at 2A, and puts out an extremely efficient 465 High CRI lumens rare in such a small package. This is achieved by our custom LED board and full copper unibody construction. For eelctrical conductivity and appearance, we have also silver plated the copper.
Introductory Pricing! Use the coupon code: X60L315 to get 15% off from now till the end of January! (While supplies last)
Specs:
Powered by 3x Nichia NVSL219AT-H1 High CRI (92) 4500K (Neutral White)
Modes: 3 Mode (High, Medium, Low)
Current: 2A +/- 100mA
Input Voltage: 3-6v
Supported Cells: 1x18650/17670 Li-ion cells or 2x CR123 Primary Lithium cells. Do NOT use 2x RCR123/16340 Cells.
Dimensions—Length: 29mm (40mm with spring), Weight: 38g (1.3 oz)
Compatible with: SureFire P, C, Z,
Features:
Pure Copper with real silver electroplating for superior thermal and electrical conductivity
Triple XP-G2 Optic with up to 90% optical efficiency.
Reverse polarity input protection
Over-discharge protection ~2.75v (applies only to High and Medium modes)
Gold-plated spring
Linear current regulated. No PWM.
Thermally potted driver
Includes:
X60L3 Drop-in module
60DC (case, removal tool and wand)
28.5 x 2.9mm AR glass lens
This Dropin is OUT OF STOCK, eta 6 weeks.
https://illuminationsupply.com/edcpl…ite-p-320.html
In nuetral white now? That’s an awesome deal on a nuetral triple.
I ordered from illumination supply
http://www.cpfmarketplace.com/mp/showthread.php?283185-EDCPlus-IS-X60L3-Triple-LED-P60-Dropin-Introductory-Discount!
Not sure but I think I ordered coolwhite. Didn’t look for color options :stuck_out_tongue: oops
If you read at the bottom of the page on illumination supply it says Manufactured by: EDC Plus. If you go to EDC Plus, it has the same page, same price, same coupon code….and is in stock.
http://edcplus.com/edcplusis-x60l3-triple-nichia-219-neutral-white-led-p60-dropin-p-131.html
Yep, but illumination supply has cheaper shipping to Canada :wink:
thanks, so one on its own would only be like 150 Lumens?
is that all one can give?, or is the driver at low?.
would one alone with a higher driver, be just the same?.
thanks.
I’m pretty sure the Nichia 219 puts out about 150-200 lumens. Like any neutral LED the output is less than cool white. The warmer the tint, the lower the output. It has something to do with the gasses that are used in the LED to warm up the tint. The gasses partially inhibit some of the light from escaping.
I think the last time I ordered from EDC Plus, the shipping was $5.
hi thanks, so better get a triple 219 if you want more then.
thanks.
The total drive current is rated at 2A +/- 100mA , so between 633mA and 700mA per emitter, which is less than the rated maximum for the 219 H1.
I have a Nichia 219 in a P60 drop-in driven at 1.4 amps and it measures 215 lumens OTF. 1.5 amps is the rated maximum so you won’t see much more than that in true OTF values.
I'm constantly amazed about how much people pay for such stuff.. still having the quad from CPF @ 230$ in my mind. Weird.
Yes I agree, sometimes the prices are crazy but I’ve wanted a quad ever since I saw this pic. I already have the blue L2P but the quad is out of my budget. The triple is pretty reasonable though.
But why dont you just build one yourself?
That quad is with trits.. also expensive. :D
Just ordered one, been wanting to try out a 219 for awhile now.
i saw this too… very nice
It won’t work in my Malkoff MD2. I’d have to pick up a solar force host.
I should have mine today..
For the quad lovers , i'll do a comparison against my Quad from memory ( just blew up few days ago)...I have a Quad XpG2 arriving today, although this one requires a full weekend to complete...
Is this drop in waterproof? Seeing that it looks as if it has glass secured to it due to the optics. It looks like it is made like the M60’s were.
the dropin is built to go into a host that already has a window - it is not waterproof on its own.
the optics is not protected by glass for maximum output.
Craig
ri chevy,
I’d say yes but only provided that your P60 host (such as the SolarForce L2 series) has good water-proof/resistant properties
