Okay we are at the end i guess, So i am fixing this thread up i will remove some things and post all pics from the different dates here so its easier to find. I will keep the stuff about my finger.
My build was meant to be a headlamp but i had to put that on hold because of my finger. I had the idea already in my head but it seemed like a task i couldn’t Handle at this moment.
New build is meant to be retro a flashlight/torch of some kind, i am a telecommunication technician by trade and i like all the retro old school items i used to come across at work. Some telephone exchanges still had massive wooden switch boards in place and they where awesome to look at. Old random items like analogue multi-meters with leather cases or wooden boxes and other test equipment gave me the inspiration for this build.
I am posting all the pics in the first thread this thread but i am leaving the writing in each reply please scroll down to see the progression in proper time.
My build items used
- Tasmanian oak
- Aluminum flat bar in various sizes
- Wood glue
- Superglue
- Screws
- 2 Triple XPG3 boards in cold white with optics
- BLF A6 driver
- Dual in parallel 18650 battery holder with brass terminals
- 20 AWG wire all around
- Clicky switch
- Heat shrink tube
- Brass handle, hinges and lock
- Solder
- Hot glue
- Varnish and stain
Tools used
- Saws
- Drill press + Cordless drill
- Sanders (Bench and hand sanders plus i tried an oscillating sander it was meh)
- Files
- Heat gun
- Soldering iron
- Hot glue gun
- Screw drivers
- Lots and lots of clamps
- Paint brush
- Pry bar ( i glued it together to sander the edges so i had to open it again lol
- Hammer (tapped wood straight)
- Snip and side cutters of various sizes and stuff
- Tweezers for soldering
I was meant to start the build this weekend cause my girlfriend is in Western Australia for a few days but last night i made a booboo lol. I sliced of part of my finger so i can’t lift much today probably for a few days. I just hung out the washing and its sore and bleeding a tad.
I lost enough blood to make me laugh at every thing fairly cheap high hahaha.
I was trying to walk it of but it wouldn’t stop bleeding.
Build thread starts here it can also be found in the comments on various days
Day 1
Day 2
Night 2
Day 3
Early morning day 4
Late night day 4
Day 5
Day 6
One whole day of sanding lol
Day 7
Day 8
Finally!
This is the very end product i varnished a few odd areas and the switch to make it all pretty. I also extended the negative cable to the switch cause it was a tad short
Beam shots
The light is using the BLF A6 driver. Seeing as the light has 6 LEDs its super efficient and bright in the lower modes. All these pics are taken at ISO800
Usually the yard doesnt look that big but its the camera playing trick with the wide angle you can see the length to the fence
Just for comparison we have my comp build to the left and an actual BLF A6 to the right you will see the tint difference
Mode 6 the difference here is clearer then the rest of the pics
Both lights in direct drive you can see the A6 is washed out by the build but you would expect that.
Way to much light for the yard the Convoy L6 is on the right and my build on the left. Plus you have a hot spot vs pure flood
Very last pic for now Eagle Eye X6 with a SST40 Direct drive to the right and my build to the left. Interesting note is the difference in tints between the two both cold white.
