Thanks Tom Tom, nice descriptive of how it all plays together.
Ryzbor
(Ryzbor)
402
I’ve sold my ROT66 literally for this particular reason.
JasonWW
(JasonWW)
403
I got it now, I couldn’t really understand how the levels between 0 and 150 LM (channel 1 I believe) could cycle between two levels without turning off. It actually does turn off because it’s PWM.
It’s just the higher channels above $150 (channels 2 and 3) that don’t ever turn off completely. They do actually, but the channel below it stays fully on, so the led stays fully on. It makes sense now.
When I was looking at the Atiny85 data sheet it looked like it only had 2 outputs that could do PWM. Obviously we have drivers like this D18 which has 3 outputs that all do PWM.
Can this MCU do 3 PWM outputs simultaneously or only 2 at a time?
(Tom Tom’s link is over my head)
I’m probably getting too technical for my own good. I’m just glad to understand the basics.
It can do 3 with full hardware support, or 4 with sort of a software hack, or up to 6 with even dirtier software hacks. But channels 4/5/6 aren’t stable enough for lighting… the resulting signal is dirty. So for our purposes, it’s limited to 3.
JasonWW
(JasonWW)
405
Thanks. Another quick question, are all of the eight pins assignable? It seems like pins 4 + 8 are always ground and positive. Is it the other six pins that are assignable? This has always confused me.
Yes. This is the chip we’ve been using:
JasonWW
(JasonWW)
407
Yeah, when I saw that I could not identify anything other than vcc and ground. The rest is Greek. Lol
The parts needed for PWM are OC0A, OC0B, OC1A, and OC1B. So it should be able to do 4 channels. But two of those are on the same pin, so it’s really only three channels.
Tom_Tom
(Tom Tom)
409
Vcc and Gnd supply the power, are hardwired to the silicon.
Leaving six configurable pins. Now that we have an e-switch, switch LED, three LED driver banks, and possibly an Aux. LED board to control (though that can run autonomously from its own MCU in Lexel’s proprietary design), we have run out.
Some pins are reconfigured during flashing, which has to be considered, so anything attached to them doesn’t interfere with the process.
The ATiny85 is now a very old design (2005 introduction).
Since then, Microchip took over Atmel (2016) and have developed the platform, also introducing technology from their PIC designs. Tiny leadless SMD packages allow much higher pin counts (though are more challenging for DIY assembly.)
This is where future development will have to go, and from where I would be starting, as a new developer.
Legacy code bases can be ported, and design environments updated. Already happening, e.g. see Adventures in TinyAVR 1-Series
Tom_Tom
(Tom Tom)
410
TK, Texas_Ace has posted some worrying information about his experiences with Anduril thermal control on the MF01S, hence his decision to stick with Narsil.
Do you have any comment, considering that the D18 is quite similar in scope ?
dmsoule
(dmsoule)
411
She addressed that question here:
Tom_Tom
(Tom Tom)
412
Strictly it only needs one PWM channel, since only one thing is PWMed at a time. But because of the way the pins are configured, at least two are actually required.
Mike C uses a different topology, as I understand it only a single 7135 is PWMed. Others are switched in in binary sequence without PWM to provide a smooth ramp and potentially better efficiency, but this requires more pins, hence he has moved on to newer devices.
Led4power has also developed his own design, using a FET operated in linear mode, not using 7135s.
There are many ways and other ideas how to do all this, meanwhile this sort of design, and firmware from a couple of active coders, is what we have.
Harborseal
(Harborseal)
413
I agree with the 4500K. It’s buy far the most useful tint in the outdoors. Where can we go for more info on this light?
JordanZHP
(JordanZHP)
414
toobadorz
(toobadorz)
415
Hello TK, I did observe PWM on both level 50 and 100, on my D18. And after some experiments, I found that level 65 and 120 were probably the correct levels you mean. Can you help me confirm that?
Pöbel
(Pöbel)
416
I believe that is exactly how it is programmed
Turbo by HOLDING the button = 70° temp ceiling
Turbo by Holding the button for 6s, then releasing the button = 50° temp ceiling
the reason behind this being, that as long as the light is in your hand you can react if it gets too hot. If it is locked turbo but not in your hand, you do not want it to be 70° when somebody picks it up.
The D18 hasn’t even started shipping yet. I sent Hank the final firmware just four days ago. Are you thinking of some other model?
Yes, I am familiar with the Meteor’s UI.
This test used UI 3. It has “turbo 70C” while physically holding the button, or “turbo 50C” while not holding the button. I was not holding the button during the 76-minute-long test. So it should have had a limit of 50C, but in reality it was much hotter.
Both lights had the same temperature limit in theory, but one was too hot to hold while the other stayed at a comfortable temperature. I assume this was due to poor calibration on the M43, because that is a known issue with the attiny85 chip and the M43 has no function to work around that issue.
toobadorz
(toobadorz)
419
No, I’m (probably) the first one who has received a purchased D18
. So I did mean D18…
Easyrr
(Easyrr)
420
Pics please or it have not happened
