This makes no sense. There is no noteworthy difference between an incandescent and a 95CRI 2700K LED light of the same brightness. Such warm-white LEDs don’t emit additional blue light like high-CCT LEDs do. There’s is also no UV.
Also, humans are not adapted to incandescent lighting for “1000s of years”. Light bulbs have only seen around for maybe 130 years.
Humans are used to the sun (full spectrum light with variable CCT and brightness changing with the time of day) and maybe a fire in a cave in the evening. Nothing else.
There’s been recent research observing how the body responds differently to blue light than longer wavelengths, and potential negative effects of prolonged and/or nighttime exposure to elevated intensities of blue light. It is often misunderstood and in some cases misleadingly exaggerated, but does not point to concerns unique to LED’s.
Then an LED is also, by definition of the word, incandescent. My son has a lot of gas, if I lit a lighter behind him when he was “emitting” would he then become incandescent as well? Just a before coffee in the morning random thought… I’m bad, I know….
Being as how the Sun is considered a Star I’m pretty sure it’s beyond the incandescent theory. (An object that emits light when heated, since the sun isn’t “heated” and can’t be turned off, Star it is) Just trying to keep within the definition of the word…
It is heated internally, and the key point about incandescence is it is light emission due to heat, so the sun is incandescent, and it’s spectra approximates a black body, modified by both absorption and emissions lines of specific elements present in the sun, then further modified by absorption of earth’s atmosphere.
The normal definition of the word refers to incandescence of the visible portion of the electromagnetic radiation due to heat. The sun also has plenty of UV and infrared.
All at far higher intensities that normally experienced from LED sources - Emisar D1 and similar or more powerful throwers being exceptions at close range.
