@mobiuscorpus, at 3.6A 6V, it should be enough, although I personally consider the NCR18650GA a 2C(7A) cell rather than a 3C cell for cycle life reasons.
So yeah, it should be fine, although if you want less total runtime and longer regulated runtime, something like a Samsung 30Q/Molicell P28A should be right up your alley
If you donāt use turbo much, then the NCR18650GA will be just fine
I donāt know if itās the same driver, but I just emailed Hank and he said that yes, you can special request the backlit button on the D4Sv2 with the new boost driver. So I did. Also, I donāt know if this is common knowledge, but you can also special order the backlit button on the regular, non boost, non tint ramping driver. I can confirm this because I have one.
I believe Hank mentioned he had plans for it, but it didnāt seem that prioritized/ it would take some time anyways. Donāt count on a D4 boost driver for the coming months is my best guessā¦
Basically itās just the D4V2 right angle model, which will have the exact same configuration as D4V2, including linear dual channel driver, and boost driver options.
if it is very similar to the D4v2 model, I wouldn't imagine there is room for a threaded retaining ring. If Hank is staying true to his "as small and powerful as possible" vision with this model.
