First time posting, just wanted to toss a thanks out there for this forum and Hank for making some fantastic lights. I am a proud owner of KR4(SST-20,4000k), and soon to be K1(SBT90.2).
Couple comments/questions; anyone out there with some K1(SBT90.2) beam-shots? I have seen a couple on reddit but not very good quality, though the impressions were that it was the most useful(the guy has W1 white, green, and SBT90.2)
To Hank, are there any plans with the KR1 to run a 21700? It seems like a head that size would go well with a 21700 tube/tail. Also any thoughts of other LED options? Id buy in a heartbeat if you upped the battery to 21700 and tossed in an SBT90.2. It would be a sweet spot between the K1 and KR4 for me. Also following closely with interest over the new clip design.
If you cant tell, I am a bit in love with SBT90.2 ever since I got my hands on an Acebeam K30-GTvn (Acebeam K30GTvn - Medium Size Throw King R - Sky Lumen). I replaced half my light collection with this thing. Vinh is starting to toss 90.2’s in almost every light it seems like, with outstanding performance.
Lastly one constructive critique of this thread; It would be nice if we could have a single thread dedicated to each light. As a new member trying to play catch up and learn, it gets very disorganized every time there is a new light announced, the name of the thread changes and the previous conversation completely derails. At this point, its a mixup of KR4(mostly clips), K1(SBT90.2), now KR1’s and still a sprinkle of previous lights.
Hello !
I received my Noctingon KR4 earlier but I ran into an issue trying to test it. It didn’t light up at the beginning, I had to unscrew and screw several times before the auxiliary leds light up in rainbow mode. But the SST20 did not light up when I pressed the tailcap button. I changed the cell from a flat top to a non-flat top samsung 30Q and it worked for five minutes. After that I wanted to test Anduril’s functions and since then it hasn’t worked at all.
I think there’s something wrong with the connection, maybe with the tailcap button, but I’m not sure.
Is there a way to reset the flashlight to make sure Anduril isn’t blocked? A way to fix the connection problems?
So I tried the way to reset that is wrote on the Anduril diagram on the webpage of D4V2. It didn’t work but I tried tightening the tailcap and getting out of all Anduril’s modes one by one. I managed to get back to normal mode and now it seems to be working.
Then I tried your solution to reset, so I unscrewed, held the button and screwed and and it seems reset, so it’s perfect !
I do have a problem of false contact if I use a flat-top battery as well as other times a bit randomly because I screw it back on. It’s a bit of a shame, I had read in this test ( Review: Noctigon KR4 (18650, 4xE21A 5000K, CRI96) ) that you could use both types… But I’m glad I managed to get it to work and I’m having fun with it.
It sounds like a really nice update to the D1… same size, but the beam is ~3X as throwy and the driver stays regulated at every level.
If it was up to me, I would make it this shape:
This makes it comfortable to carry at the waist, with the clip toward the body. The straight edge and low profile tip prevent it from pushing into skin.
A 2-way design would mean there is an entire extra layer digging into skin, which hurts after a while.
From a streambody shape just becomes an ordinary fat straight flashlight with that straight long clip. So the narrow waist is lost.
Also lot of empty space that really does not add any pressing of the material at all as it is not a straight flashlight, because with a straight flashlight you also have that pressure not only the single point of pressure, so a straight clip presses alongside a straight tube. Of course one could argue against this should the person want to.
Yeah it solves the need of deep carry, but that still does not mean it suits it or it doesn’t add more than it has to add in the tube area.
The clip has to be more elegant rather than be again just looking from another flashlight, criticism against the current clip.
Will the E21a only be available on the KR4 or will there be a D4 format light with the regulated driver and E21a?
Any plans for E21a in a titanium host?
This is not going to delay shipment of the current design light, right? By the way do we know when it’s getting sent out to those who have preordered?
Thanks
