In smooth ramp mode, is there supposed to be a little ‘hiccup’ somewhere half way through the ramp? By hiccup I mean a brief hesitation where it seems like the light shuts off for a split second and comes back on at a higher level, and then continues ramping up from there?
Also, I realized the Shockli cell doesn’t make contact with the terminals of my Miboxer C4-12. So now I’m stuck using the “slow” Lii-500 to charge it. Sigh.
I use the MiBoxer C4-12 to recharge my Shockli’s all the time…. check the negative terminal of your charger, you might have to bend it forward a bit so it stands straight up…
Pm says an unspecified manufacturer wants insider production details about Emisar lights. Even if Emisar shared that info with me, the answer would still be “no”.
A while back, before the D4S was released, there came word that the D7 wasn’t going to be realized. Not sure what the problem was though. I’m a bit bummed, but with the success of the Emisar lights, I’d expect that we will see some more cool designs in the future.
In Turbo mode with water cooling. After 50 minutes, the flashlight went into a lower brightness, the voltage on the battery was 2.8-3.1v. Battery Shockli 26650 - 5500 mAh. (Video in fast mode)
