Hi, I'm ready to pull the trigger on the Emisar D4SV2 but not sure about the extra optic option. What is it? The option says more floody beam. I'm thinking orange peel reflector but it says EXTRA. Is it something you can swap out or add on to the light?
I also have a couple battery questions. Will it take flat top batteries? What is the minimum amps I should be looking for without sacrificing max brightness? The choices I'm seeing range from 7 to 40 amps.
Here are the available options:
Body Color --- Please Select --- Black Dark Grey Cyan Picked Cyan
Switch Back Light --- Please Select --- Cool white Warm white Amber Red Cyan Green Blue Picked Cyan
LED & Tint --- Please Select --- W2 (Osram CSLPM1.TG), 6000K (+$15.00) Cool White, SST-20 6500K Neutral White, SST-20 5000K Neutral White, SST-20 4000K, 95CRI Warm White, SST-20 2700K, 95CRI Neutral White, XP-L HI V2 5D, 4000K (+$10.00) SST-20 660nm deep red (+$5.00) 219BT-V1, R9080 neutral white, 4500K (+$5.00) 219BT-V1, R9080 warm white, 3500K (+$5.00) 219BT-V1, R9080 warm white, 2700K (+$5.00) 519A 5700K dome on (+$10.00) 519A 5700K dedomed (+$10.00) 519A 4500K dome on (+$10.00) 519A 4500K dedomed (+$10.00) 519A 3500K dome on (+$10.00) 519A 3500K dedomed (+$10.00) 519A 2700K dome on (+$10.00) 519A 2700K dedomed (+$10.00) Picked W2 (Osram CSLPM1.TG), 6000K
Parts Options
Add a stainless steel bezel (+$2.99) Added
26800 tube (+$13.80)
26350 tube (+$4.95)
Add magnet in the tailcap (no magnet in the tailcap by default) (+$2.99) Added
Buy an extra tailcap without magnet (+$6.99)
extra optic with more floody beam (+$2.99) Not sure
Dual bay Li-ion charger(battery not included) (+$15.00)
It is basically just a matter of unscrewing the bezel and swapping the optics, but it’s not something I’d advise doing “on the fly”
The optics are fragile, there’s a glass lens and o-ring, and you want to keep everything clean. While the optics are pretty easy to install at a bench, sometimes they don’t want to come out, and installing them wrong could damage something.
