My new D4Sv2 suddenly stopped working properly. I’ve only had it since January and it has had a couple of hrs use maximum due my rotation of lights and my tendency to baby new arrivals.
Configuration: Black, 26800 tube, steel bezel, 5000k 519a, brand new qb26800.
It’s weird, the last Emisar that gave me issues had a black body too. A curse?!? ![]()
Symptoms:
The main emitters flicker when turned on and will not produce much light.
ramping behavior is inconsistent. Sometimes it has no effect on the main emitters and only the button brightness changes. Other times being at low ramp produced an almost-steady beam and ramping up caused tons of flickering. Mostly ramping doesn’t accomplish much
turbo is also inconsistent. It seems that turbo works in the Advanced UI but not in the Simple UI. The flickering begins again immediately after exiting turbo.
Factor reset changesd the aux leds back to the default rainbow cycle but doesn’t fix the issue with the main emitters.
I was also able to reconfigure the aux leds with the 7c and 7h method back to what I had prior to the resets.
bat-check works but the beam has flicker in the blinks
Can someone tell me which version of Anduril this light should have on board? I have the flasher and I could try re-flashing the firmware before I give up and ask Hank for help. This light has the FET driver with a backlit button.
What I’ve tried so far:
- multiple factory resets using different methods
- cleaning all contact points between the tube, the head, and the cap as well as both springs and the ends of the battery.
- using a different tube and a different battery
- switching between simple and advanced UI
I’m sure Hank will make it right, but I want to exhaust my own trouble shooting options first.
@ToyKeeper Does any of this sound like a firmware mismatch or software bug that a re-flash might fix?
