I bought two for gifts : not very light, not high CRI (not stated in my comment but implied since Intl-outdoors always offer them), not an efficient driver (PWM, not regulated), confusing interface, no PID thermal regulation.
Copper for headlamp. That will be very heavy
I also preffer to see something like my H03 with side switch. If it possible to change optics easily that also will be great. Maybe it is possible Hank to make kit with honeycomb TIR and another one for more throw. Charger is not must have. Also without it we can safe few grams.
T-shape, multi-emitter, regulated driver, USB-C charging, and Anduril 2 would be perfect for me.
I might be still be interested in a right-angle light with multiple battery tube options and a magnetic tail cap, but there are plenty of options in that form factor.
I really like the Lumintop hl3a because it’s a triple and is Anduril. The triple allows one to choose the optic to alter the beam (I’m using a mule with diffusion film for the ultimate reading light).
How about a flip-up TIR lens, hinged at the top of the emitter opening? Flip down for spot, flip up for flood. A 60 degree or so flood might be better for me.
Yes.
I tried to pitch this idea in a Sofirn D25 thread. The UI already exists. If using standard MCPCB and TIR sizes, the LEDs and optics could be easily mixed and matched.
Spot or flood. Tint mixing. Lots of possibilities.
21700 headlamp for long runtime this is contradictory, heavy weight and long use time does not work in real life. Putting a lot of weight on your forehead is for very short times.
No, depends on the design. If it’s not balanced, and is just some shitty light straps with a light, then yes, you’ll have too much weight
I expect something large will need to be mounted on a helmet of sorts
24w sunlike is not a small cob so it will necessitate being large anyways… I mean, seriously, look at the size of the cob… 19x19mm, diagonally is almost 27mm - and the place you put it still needs room for metal tube
