In high hopes to build a ~2000lm XM-L2 build, I ended up trying to find a suitable LED… 6 XM-L2’s (U2, T6 and 1 U3) and 1 XM-L U2 later… Nothing survived past 7.6A! Even when below 4.2v. The U3 mentioned above did 7A, but died when hooked up to a stock HX-1175b1 (dumb). No real data other than vf/A on a really promising XM-L2 that died at 7.6A. Oh well…
I bought some of the T6’s mentioned above and a couple more U3’s. I may try a couple of the T6’s to do 8A, but will have to settle for less powah! I have a P-bin CBT-90 and SBT-70 screaming in the drawer… Pick ME!! Unfortunately the vf of the CBT-90 @ 18A is 4.3v, was hoping for less. It should be making between 2500-3000 of very inefficient LED lumens though.
I also bought a light meter, so I should be able to start measuring output as soon as I get a light meter built and calibrated.
But everybody has been doing low res mods for years. Many years.
And I still like a direct drive light. Hands down it is my favorite. So as far as I am concerned its still good.
Sure it was, really, funny to see a single XM-L light pull 8 amps from a low resistance setup with a good cell.
But the output was just not there compared to the XM-L2 led at lower amps. Back then we all vailed and carried on about whether it (XM-L2) would be the end of single cell lights. It was not.
And I still have enough Xm-L lights left over to test it. But nothing I measure is calibrated by any method commonly acknowledged or understood explainable on the forum. So I can only say that relatively speaking a XM-L light doing 5A is about equal to a XM-L2 light doing about 3,8A. For anyone caring that amounts to about 1360 lumens in my converted Ikea bucket of light.
As far as XP-L vs XM-L2 then the only tests (in a single thread as far as I remember) that has light output included are done by hpflexpro where they are equal. So of course it is brighter to have a higher amperage capable XP-L. I understand that. But it is a little marginal to me.
I can't believe I said that. I may have to find another hobby. Things are shifting in my world. Sorry for intruding. I'll sod off now.
I don't know how I missed this thread until now, but I hadn't seen it until today.
I do think that the newer batches of emitters are different than the older ones--and not just the U3 bins, but the T6 and U2 as well. I've seen the vF shift in the newer batches of T6 4C emitters as well. They just can't pull the amps like the old emitters could.
That said, the higher bins seem to put out more light at less amps, so all is not lost. I wish we could have more efficiency and higher amps, but I guess we will have to wait.
I now have a 10A linear power supply (extremely small ripple current--basically non-existent) and the newer emitters just can't be cranked up as high as the older ones. 7A is difficult with a lot of them, even with a very smooth output.
With a stock HX1175B1 you are almost guaranteed to blow any XM-L2 you hook up to it--especially a newer batch XM-L2. It puts out around 7.5A stock and has a lot of voltage ripple on top of that.
Unfortunately I haven't been keeping good notes on things--I've been too busy and burned out to do it right, but I have built 30-50 lights with these newer batches--lights that I've built with the old emitters as well--so I've been able to see the differences in lumens and amp draws.
I ended up with a Yihua PS-3010D. It's a beast of a power supply, and a great price, but it has some flaws from the factory:
The current measurement display is not calibrated correctly. Simply remove the face plate and calibrate with a known load or source (I used 2x 0.5 ohm resistors in series, along with two multimeters to check voltage drop and total voltage).
The chasis ground was not great. Fix while you have it apart.
The output will spike sometimes if the power is turned on and off. This is also easily fixed by adding an extra capacitor to the board (see video link for overview and all of these fixes).
Fixes video:
http://www.youtube.com/embed/Osc1--tmzlQ
If you need a high-output power supply on the cheap, then this thing delivers. Nice smooth output--and lots of it. Be prepared to make the fixes shown in the video. It is large, heavy, and loud, but nothing else in the price range even comes close.
Any thoughts on the different voltages on the XML-2 3C leds?
[/quote]
The emitter from the EE X6 was still attached to the pill and stock copper mcpcb in the flashlight since some thermal adhesive was used and I did not plan on swapping it. Voltage was very similar to the CW XM-L2 U2`s that fried below 6A. Im guessing it might have been good for around 6A. It had fairly typical voltage for a "new" XM-L2, but slightly on the "low" side. When I say "low", i mean closer to the "good ol emitters"
The U2 3C from IOS had very high Vf. This was actually higher compared to the XP-L V6, which is just wrong. Id guess I was just extra unlucky with that one.
I think they just represent two sides of what we risk to see when buying XM-L2s. I would not bother using any of those with the H6Flex at "full throttle".
:beer:
Sorry to hear about your U3. Ive had 8,2A out from a stock (resistor modded) HX 1175B, but that is pushing it. It was a temporary test with an old XM-L2 T6. Its nice to see your U3 handled up to 7,6A though. Just strengthens my theory that low Vf emitters are more capable of higher amps before they fry. I knew you had a winner. Not a single one of the emitters Ive bought lately would have been capable of that.
7,6A though a stock HX-1175B in general is gambling no matter how good the emitter is though.. Id recommend XP-L @ 7A and a HX-1175B modified for low ripple next time you want to push the limits.
@ Ledsmoke.
Feel free to stay and share your thoughts. Btw, are you tired of living up to your username or something? :D I find the data very useful. Helps to avoid any damaged LED`s and learn more about the headroom. Also, in single cell DD/linear lights Ive been really enjoying to use the emitters I had data on. They performed just like expected in terms of amp draw. Often when making such lights there are lots of differences in peak amp. Sometimes its hard to pinpoint exactly why, but knowing the behavior of a certain LED just makes everything clear and simple. :) There is usually little or no more guesswork on the weak link. I can then handpick LED`s for the type of driver they suit best.
@ RMM
Thanks for sharing. Sounds like your experience go hand in hand with my data and experience.
I got mine for close to nothing. It had been used in a professional work environment. Its really big an its heavy, that I know. Anyone familiar with Farnell? Just curious...
^ Interested in hearing feed back on the Farnell too.
Just wanted to thank you again for all the effort you have put into this research and reporting RaceR86. Very good information and I hope it eventually leads to discovering the underlying cause of this new issue with xm-l2's. If not, atleast we have some potential clues for identifying the more vulnerable emitters.
I do agree that the higher vF emitters can't take as much peak amperage. I suspect that the peak voltage all of the XM-L2s can take is similar before they blow, but it takes more voltage to get there if the forward voltage is higher so you hit that limit with less amps.
Its does not seem too far from the truth, but there is some strange stuff going on. Look at "RIP V" in the spreadsheet.
XM-L2 U3 went all the way to 4,27V. Most U2`s said farewell around 4,05 (+/- 0,07v). Something strange with that U3. Djozz`s U3 were quite similar. I dont know what to make of the U3. I dont like to push any of the XM-L2s beyond 4V. That is danger zone. But maybe not so dangerous for U3???
When it comes to new T6 and all U2`s Ive tested. If the Vf is 3,78 @ 5A or higher, then its not suitable for really high amps. If its 3,7V or lower, then its good.
RMM, have you come across any XP-Ls that could not handle 7A? Or have you noticed any with extra high Vf compared to the average? So far everything I have seen seems quite predictable and fairly consistent.
Did a quick test on two emitters from the Supbeam X60. I stopped testing at 3 and 5A. Not suitable for really high amps. I have not added them to the spreadsheet. One were bad the other one were really horrible.
If anyone at some point stumbles on a batch of high binned XM-L2`s (preferably U3 if CW, or U2 if NW) with consistent low Vf, let me/us know..
I haven't tried pushing the single XP-Ls as hard simply because I don't have any lights that I've wanted to put them in yet. 99% of the XP-Ls I use go into small triples with a single cell where vF is not an issue.
This is anecdotal but Hank (from IOS) told me that in the emitters he's tested the XP-Ls could go up to 1A higher than the newer XM-L2s. What I don't know is if the process or construction has or change on the XP-Ls to match the newer XM-L2s but we just haven't seen those emitters yet.
A couple of possibly stupid thoughts (on my part) but maybe relevant......
For the LED manufacturers, but not to be ignored, the usage of LED's in flashlights is an off-shoot and not their mainstay.
I have 35+ years in the automotive repair side of things and 16 years in the sign business. Concentrating on automotive - the common DC voltages for automotive are 5, 12, and 24. For the last 20 years the electrical systems have been over-taxed tremendously. Just not enough available amps at 12VDC and the 48VDC system was deemed long ago to be too expensive and dangerous at the time. Amperage draw is a killer.
The usual lighting systems of the prior 75 years was just too taxing. Instead, manufacturers started looking for ways to drop the current draw to allow for more wanted toys and computer controlled systems. The first line of thought was fiber optics but again that was cost prohibitive to use on everything but higher line vehicles. Instead, the most prominent of the last 10 years was the implementation of LED lights. .
Now if I was an automotive engineer I could see myself telling CREE and companies that I would love to use more LED's but because of the electrical system's limitations that I will just keep pushing forward with fiber optics. Based on what I am learning here at BLF that is actually happening. The LED manufacturers are creating more efficient LED's with the equivalent wattage but lower draw.
So what is "our" next move?
Higher voltage batteries and forsake the high drain batteries? (I am not referring to 2 or 2+ cell lights).
Is anybody aware whether or not the battery manufacturers have anything in the pipe?
Would the focus of higher voltage batteries also change/increase the focus on mAh capacity?
Again, possibly stupid but maybe relevant - dunno :) More qualified people here than I to hopefully answer :)
I am still curious to hear thoughts about the increased Vf of the new emitter and possible solutions.
I have been thinking about this and speaking with many others and all seem to say that greater voltage would be required which leads me to think about boost drivers for single cell lights.
Here are a couple more questions that I have:
What component regulates voltage on a driver?
Does anybody here have a way to test an emitter only with a higher voltage but lower amps? (I would ask RMM but he is busy as hell right now :) )
On the topic of resistance mods: I have a luxon K2 light that I did spring bypasses throughout the whole thing. On 3AAA duraloops, I could approach an amp vs the stock 500 ma it gave me with 3 duraloops.
Can we get one of these high Vf LEDs into an integration sphere and see what is going on?
No, you need something to limit/set the current (driver) and a heatsink for your ledboard. Without driver the led runs direct drive on the battery which may or may not work, that current (-6A) is already dangerously close to fatal to the newer Cree leds.
