Gentlemen,
Today I present the testing results of a new emitter/pcb combo from Illumination Supply. What's new here isn't the emitter, but the new 16mm pcb that it's mounted on. The official name is " Cree XM-L2, 16mm Round MCPCB Copper Direct Thermal, U2, 1C (6500K) " . Kind of rolls off the tongue, doesn't it
... As Dr. Asimov famously penned "What's in a Name?".
Without further ado, let's see how I.S's "Boreal Base" fairs in the Sphere-O-Truth.
As the above graph is a direct comparison to a standard 20mm aluminum star, it should be obvious by now the benefits of direct mounting emitters to copper. Combine that fact with these now being readily available from Illuminationsupply.com, there's really no excuse for your light to be sporting anything so blase as last years tech.
For full disclosure, this sample was provided to my by Calvin at I.S. Granted, this is much akin to getting a sample dime-bag from ones local drug dealer. Free? Muhahaha.... If my last couple of years paypal statement means anything, Craig and Calvin know I'll be back.
Since it will be asked, let's take a look at a comparison against the Sinkpad:
A couple of things to note:
- The plating on the back of the I.S. pcb is stated to be nickel. Not sure why this was done, and as the above pic shows it is a very thin layer. Pic taken mid-lapping. (You don't lap your pcbs???- Luddite...)
- The Sinkpad is 20mm vs the 16mm I.S. pcb fare. This may explain the differences in output at extremely high current. Also, the differences could be merely be due to Cree's binning tolerances.
- This test was actually completed almost 2 weeks ago, but in because I'm a big slacker, am only getting around to posting it now.
As always thank you for reading,
-Match
(beta post - will clean it up and add another pic or two tonight)
