ENDED
Where? How?
Same, where is the link for the lazy people like me?
Yes … purchase info please.
I hope the 6000mAh rating is close to true. If so, I’m very interested.
I’d be really surprised if those were 20A continuous discharge like it says on the label.
Honestly, there's no standard yardstick for label/wrap specifications, and it is anyway wise not to blindly believe in them.
Bench test results I'll wait for.
Cheers ^:)
When can we get some independent tests? I really wonder if it’s the same cell as Shockli which was measured >5900 mAh at low currents…
https://www.aliexpress.com/item/2-pcs-Original-KEEPPOWER-IMR26650-6000mah-E-CIG-Li-ion-rechargeable-battery-30A-discharge-high-drain/32850787447.html?spm=a2g0s.8937460.0.0.ssos2j
https://www.aliexpress.com/item/2-Pcs-Original-KeepPower-6000mAh-26650-P2660C-protected-Li-ion-rechargeable-battery-3-7V/32848209408.html?spm=a2g0s.8937460.0.0.ssos2j
Amazing price at NKON - almost half of other vendors! :+1:
I’ll probably get a couple, just because. :person_facepalming:
Thanks all for flagging these up and providing links.
I’ve just ordered four of the protected version from NKON
I’ve also added them to HKJ’s review request thread - it might save him a little money if he was planning to test them anyway:
Any BLF review of cells?
Can’t find any test of the new one, but there are several of the older ones. They score good on capacity but less on drain (10A).
http://lygte-info.dk/review/batteries2012/Common26650comparator.php
they should work in convoy l6 right? Hard to tell if they are flat tops or not.
They look to be ‘raised top’ and may make contact in serial, but if they don’t a small magnet between them should do.
I ordered two unprotected.
IF this is PLB 55A cell then you can get the unprotected variant for less from Shockli.
