ENEDED
However, it was a V1 driver. And the light suddenly turned on and stayed on (couldnā€™t turn off, one bank of LEDs on full power) shortly thereafter, so possibly it was just a symptom of faulty driverā€¦
Is your light from first or the second batch?
PS. Still no further info from BG - they gave me an order number for the MF-01 head but I canā€™t find it anywhere.
Yes this is from the second batch, I donā€™t mind the turbo step down because I really donā€™t need it for that long. And I can always just double click to bypass it to turbo again.
The high mode is running plenty amount of light and it ran for more than 35mins before I got boredā€¦ normal night walking on medium is also more than enough for my personal usage. The high and turbo is like the boom button to surprise friends or a quick boost for me to identify objects farther away.
You are also convinced of this. About what I said ā€¦
Itā€™s a shame they donā€™t have a colored stainless steel version like the S41 :sunglasses:
Hmmmā€¦ and after the stepdown kicks in, if you bypass to turbo, does it again wait 1,5 minutes before dimming again?ā€¦
My v1 after stepdown kicked in, if I went to turbo again, dimmed nearly immediately. Same after unscrewing/screwing. The head was really hot, over 60.
In wind and rain, there was no stepdown at all.
So , possibly there is added timer in v2 to prevent damaging from too high currend over a long time (I suppose not all parts are cooled equally well, some components of the driver can fail even if the outside is cooledā€¦
Will there be a group buy for the forklift that goes with it? :wink:
Turbo it back on it will step down almost immediately as you described, Iā€™ve also heard that second batch produce more lumens so therefore more heat than the first batch, but donā€™t call me on it because the ice bath is cooling the light externally, not the driver which is internally.
From my basic comparison with my MT03 which has 9000 lumens (some tested higher up to 10k in BLF), my MF01 is definitely brighter. Bright enough to just covered the beam on my MT03.
hello
I have a V1 MF01 host running a modded driver with NarsilM. I set the turbo limit to 60Ā°C. I reach this limit in 1min47sec (room temp is 19Ā°C)
The MF01 has a very very small head design and fins are inexistantsā€¦ Itā€™s not a performing light for lumens but a ā€œpocketā€ big boy floodier.
In comparaison the MT03 also running a TA driver with narsilM has the same approx output (10000-12000lm) and can sustain turbo for 5min without problem. Fins are really deep and head is two time the MF01 head size.
No secret in this turbo timing. Acebeam light have big heads with big fins.
But when you see the MT07S with TA driver NArsilM that can sustain 9000lm for5minutes and for 1/4 price of the ACEBEAM lights :wink:
V1 driver picts
So ive just receive the light
Apparently, itā€™s mateminco who made this light
They changed the led wiring, from 6s3p to 18s i guess( or maybe 18p, i cant track the wire, but i bet itā€™s 18s because the wire is quite thin for such high current)
Overall iā€™m pleased with what i paid, very bright and good looking color
sound good, looks good)
So, since the replacement head is now on the way, I thought it be time to work on repurposing the defective one. I think itā€™d be great as an off-road light. All the leds work, just that one bank on the driver is stuck in turbo.
Iā€™d like to replace the driver with either an existing standalone 12V-input driver, or Lexelā€™s MF-01 driver in a separate case. By doing this the driver is not subject to the heat generated by the leds. This could also allow the head to run longer at full power before sustaining damage.
Anyone have any ideas? Iā€™d like to have at least 2-3 power levels. Also, Iā€™m thinking of fashioning some kind of additional fins, to help pull away heat from the unit. Any help on this would be appreciated, as well.
Lastly, does anyone know what the max sustiained output could be. Keep in mind that the MCPBC would be the only board on the head that would be subjected to the heat from the leds.
A single Xp-g3 is known to hit 1,800 lumen at 8 amps.
That does not mean 1,800 x 18 = 32,400 lumen. Simply because of battery and heat limitations.
Yeah, of course too much heat can fry or at least shorten the life of the Leds. I guess what Iā€™m really wondering is whatā€™s the max safe sustained, stabilized level for the head (ex. 5000 lumens, 7000 lumens). And, if could possibly be somewhat higher, since there would not be a more sensitive driver on board.
There is no set level since conditions can vary so much. A windy winter night might be able to do 9k lumen constant while a windless summer night might only do 4k constant.
XP-G3 back in stock, #3 on the way.
If all goes well, I should be ordering #3 soon as well. Really like to get to know the boost driver better and the new 3000 lumen high mode. :smiley:
But it is very hard to find this point with all LEDs in a multi-LED-Flashlight. And some losses will appear in the optic etc.
Received my (version 2) MF-01, got the 30Qā€™s charged last night. The light worked perfectly! Very impressive amount of light, especially for the high CRI emitters.
Thanks again freeme!
Well, then what I need to figure out is what levels would be optimal for year-round use, cool/cold weather, and a turbo of a couple of minutes.
Any idea for an external driver? Or, do you know if Lexelā€™s driver could accept automotive voltages (10-14V)? That way Iā€™d still have thermal stepdown if I just swapped out the bad driver. Iā€™d just have to recruit a friend who is more experienced in soldering, or someone at the local makerspace to install the new driver.
