What I meant is that those who are in GB under the lowest limit should get their $7X codes separately so that if somebody happens to sleep late in a different time zone he wont miss his discount if there should be more people rushing to buy this! Little bit same as with BLF GT GB listing where first 555 will get it for $111.
This message is for freeme or anyone who has the knowledge. I’ve been wanting to order a fresh batch of 30Q’s for this light, but have held off because I don’t know if they used flat top or button top when they say they used 30Q to achieve their specs. I assume button top because that is what people used in the MF-01 battery carrier if they did not alter or remove those plastic pieces. Freeme can you confirm 30Q button top is the battery they used and recommend for spec? Thanks in advance!
MF-02 battery carrier supports unprotected flattop.
[quote=ramptosd]
This message is for freeme or anyone who has the knowledge. I've been wanting to order a fresh batch of 30Q's for this light, but have held off because I don't know if they used flat top or button top when they say they used 30Q to achieve their specs. I assume button top because that is what people used in the MF-01 battery carrier if they did not alter or remove those plastic pieces. Freeme can you confirm 30Q button top is the battery they used and recommend for spec? Thanks in advance!
[/quote]
